586,094 active members*
4,142 visitors online*
    Oct 2008
    Smile Mitsubishi FX1 Wire
    We just bought a Mitsubishi FX1 (non submerge) Wire , but we didnot get the software (4 pack ) disks or the pitch error disk software w/ squareness info,if someone out there that has this , I would greatly appreciate a x-copy of them. Thanks ([email protected])
    Feb 2007
    464
    I have them but I can't copy them.
    Wrong format.Any ideas how to do it?
    Stefan Vendin
    Oct 2008
    Xcopy fx1
    Yes I do know how , it is called xcopy , it is done thru dos and thats the easiest way , I am in missouri (central time) call 636-447-5521 Ray
    Monday - Friday 9:00am-4:00 pm
    Jun 2007
    3757
    Smile This will copy any (non-apple) disk.
    DCOPY.exe. Just run this from a DOS window.
    Just type DCOPY for help.
    To copy using one diskdrive just DCOPY a: a: It will prompt for disks.
    Unless the disks have laser burns, or hidden information between sectors (Intel did some of this and a normal diskdrive cannot write past the end of sector) this will make a perfect image.
    X-copy might not work, as the boot sector, etc will be from your current DOS version.
    DCOPY.exe has been scanned for viruses by AVG.
    Being circa 1991 it predates most viruses, and apart from being able to format a disk, it is harmless.
    Attached Files Attached Files
  1. mitsubishi wire cut DWC90 C2
    By camay in forum Waterjet General Topics
    Last Post: 09-08-2012, 04:41 AM
  2. Mitsubishi Wire EDM
    By Roswell28 in forum Esprit
    Last Post: 12-04-2008, 05:14 PM
  3. Mitsubishi FA Series Wire EDM
    By supercrewed in forum EDM Discussion General Topics
    Last Post: 08-20-2008, 03:21 PM
  4. Mitsubishi, DWC-110G Wire EDM
    By professor in forum Waterjet General Topics
    Last Post: 03-02-2008, 09:56 PM
  5. Mitsubishi EDM/Wire Cut Systems
    By flomatic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-06-2007, 04:56 AM
