586,121 active members*
3,572 visitors online*
    Dec 2007
    7
    Question HEIDENHAIN 151 TNC
    On a tnc 151
    When I power up I get a error message
    "relay. ext. dc voltage missing "
    Any help would be appreciated.
    M.L.
    Apr 2008
    50
    Heidenhain
    That is normal. Usually the first thing you when you turn on the machine is wait for the prompt and then press the CE button. After that the next step is to start the drives when that message comes up.
    Kevin
    Dec 2007
    7
    start up
    Kevin;
    The message"relay.ext. dc voltage is missing" is after the initial startup "power interrupted "that I always clear with the CE.
    Nov 2004
    3028
    You will get this IF you powered up with the Emergency Stop button pushed in or if you have a dead 24VDC power supply.
    George
  1. Heidenhain g-code help
    By arkum in forum G-Code Programing
    Last Post: 08-29-2017, 04:55 PM
  2. G-Code outside circle Heidenhain
    By bigtoad170 in forum Bridgeport / Hardinge Mills
    Last Post: 07-03-2008, 12:29 PM
  3. Heidenhain G-code or conversational?
    Last Post: 04-12-2008, 09:13 PM
  4. Bridgeport Interact 1 Mk2 Heidenhain error
    By joegille in forum Bridgeport / Hardinge Mills
    Last Post: 03-13-2008, 01:07 AM
  5. Heidenhain conversational code
    By a2p4me in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2008, 11:16 PM
