586,103 active members*
3,013 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Create new milling stock
Results 1 to 6 of 6
    Jul 2008
    55
    How do you create a new type of milling stock in V22? I want to create one for wood and all the defaults are metal.
    Thanks.
    Apr 2007
    8
    One may exist but I haven't seen an option to add new cutting conditions.
    What you could do is modify one of the existing cutting conditions.
    To do this goto Milling Tools, select Default, select Cutting Conditions.
    Modify one of the existing cutting condition options then select "save to file"
    Warren
    Jan 2006
    4396
    Why not just change your feeds and speeds manually??
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2008
    55
    Quote Originally Posted by tobyaxis View Post
    That is a easy solution. I just thought you should be able to create other materials.
    Jan 2006
    4396
    Quote Originally Posted by Micky15044 View Post
    Granted that is the way to go in other software packages, but personally I never use the slow feeds and speeds a software calculates. Usually I run about 250% faster and harder.
    Wood is a different story because of the fire risk.
    Give the material creation idea a shot, experiment with it, and post your results good or bad.
    It is worth a shot to see what happens.
    Toby D.
    Schwarzwald
    Mar 2008
    163
    I cut wood every day and never had a fire risk. What are you talking about Dust?
  1. create 3d dxf drawing
    By brockadeau in forum BobCad-Cam
    Last Post: 01-31-2008, 03:23 PM
  2. Milling parts to stock and thickness ?s.
    By Stampede in forum BobCad-Cam
    Last Post: 11-15-2007, 09:42 AM
  3. Milling flats on the side of round stock
    By MichaelHenry in forum SprutCAM
    Last Post: 10-22-2007, 12:36 AM
  4. Create 3D solids for milling
    By NCN in forum Uncategorised CAM Discussion
    Last Post: 02-19-2006, 01:22 AM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
