586,265 active members*
3,795 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Positional 5-Axis Machining
    Mar 2007
    17
    Hello to all you SurfCAM experts. I am new to surfCAM but have extensive MasterCAM experiance. I am using a Motion Master 5-Axis router to cut large fiberglass Patterns with SurfCAM that only has positional 5-Axis capabilities. From what I understand to accomplish positional machining I need to machine in that specific Cview with Coord:View selected. When I do this and post it the file is wrong it just rotates the Cview selected to the top view and runs in the X Y with Z depth instead of a head rotation and running in the Z Y with X depth. Is there some other parameters I need to change or is my Post Processor Wrong? Any help would be appreciated!!
    Brandon
    May 2007
    71
    Don't know what the results you want!
    Could you show your scprt and indicate where you want machining!
    You just selected the Cview and used 2 Axis or 3 Axis, then the results should be as you talk about!
  1. 5 Axis CNC Machining
    By tariqfayyaz in forum News Announcements
    Last Post: 11-06-2011, 12:48 PM
  2. 4th axis machining
    By senor J. in forum Uncategorised CAM Discussion
    Last Post: 09-19-2007, 01:41 AM
  3. 4-axis Machining
    By davebGTI in forum Surfcam
    Last Post: 02-19-2007, 04:20 PM
  4. 5-Axis Machining
    By 5AxisMachining in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2005, 04:03 PM
  5. 4th axis machining
    By senor J. in forum Visual Mill
    Last Post: 10-22-2004, 09:10 PM
