586,096 active members*
3,754 visitors online*
    Dec 2006
    5
    Lathe dont start.
    Hi, my boss have buy a old cnc lathe Baxter Furure... and before the shipping the machine work well. My problem is when I power ON the machine the 2 axe LED on front pannel blink one after the other and the axe dont work. The cpu work good, I have acces to parameter menu and offset, program.... I have check all fuse and check all plug and all card for good connection and the front door switch and the only one is bypasse. I start the cpu with e-stop and I have the ready LED ON on both axe drive and when I remove the e-stop I have the ready and power ready LED ON on both drive. And the air is plug. I dont know if a sequence of button is need to start or someting to do to start. The setector at HOME and I try X and Y joystick to homing axe and noting work I always have this 2 LED blinking.
    If somebody have ideal I am happy to try it.
    Thanks!
    Playback
Name:	CNC Lathe Baxter 006.JPG
Name:	CNC Lathe Baxter 007.JPG
    2 AXE LED
Name:	CNC Lathe Baxter 009.JPG
    2 LED blink on after the other.
Name:	CNC Lathe Baxter 014.JPG
    Axe drive LED ready ON with e-stop.
Name:	CNC Lathe Baxter 016.JPG
    Axe drive LED ready and power ready ON with out e-stop.
Name:	CNC Lathe Baxter 018.JPG
Name:	CNC Lathe Baxter 025.JPG
Name:	CNC Lathe Baxter 028.JPG
Name:	CNC Lathe Baxter 029.JPG
    24221
    It appears you have a Not Ready State, this is usually the auxiliaries have to be on, is there another control On PB? If the machine has hydraulics, the hydraulic pump should be on.
    I would guess the MTB set the two LED's up to flash indicating the machine needs to be homed.
    Al.
    Albert E.
    Dec 2006
    5
    Hi Al_The_Man, thanks for the reply. For your question, no the axe don't move. No hydrilic, only air for chuck and close or open i am not able to homeing axe. I dont know if is possible to loss a parameter? I do not have check that.
    Thanks!
    Playback
  1. Need Help lathe dont start.
    By Playback in forum MetalWork Discussion
    Last Post: 10-01-2008, 04:31 AM
  2. Meldas 50 lathe T01 CAN'T CYCLE START 0104
    By GPena in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-15-2008, 04:02 PM
  3. CNC Lathe Shopping....Where to start?
    By griffithbuilt in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2005, 01:12 AM
  4. Things I dont like about ver 19 and 20
    By carbidecraters in forum BobCad-Cam
    Last Post: 04-16-2005, 07:44 AM
  5. Dont know where to start... Mill Electronic PCBs
    By samsagaz in forum MetalWork Discussion
    Last Post: 04-11-2005, 08:00 PM
