In SW, i import or input a part to machine in one file and in a seperate file, i create my stock material size. i then create an assembly of the files and export them into Virtual Gibbs for machining. After i create and run the toolpath in VG i can only save the rendered toolpath as as STL file.
i am wondering if it is possible to convert a rendered toolpath from Gibbs Virtual, that can only be saved as an STL, back into a solid in SW's so that it could be used as material for the next machining op?
below is an stl example from VG
HTML Code:
http://rapidshare.com/files/151250564/Example_Housing_Stock_op1.stl.html
thanx for looking
