DEAR ALL
WHAT ABOUT THE VOLTAGE AND CURRENT FOR EDM MACHINE
THANKS IN ADVANCE
GAMAL
DEAR ALL
THANKS IN ADVANCE
GAMAL
I am looking into purchasing a Mitsubishi FA10S Wire edm. Can anyone give me any input into the machine?
What does the FA (vs FX) mean? Also the "S"
Am going to be cutting Titanium. Would it be a good machine?
Hello does somebody know where can I found a use board or repair the FW-01 board for a Wire EDM Mitsubishi DWC 90 CR
I have mitsubishi EDM DWC-90H could anybody help me.It work very good before i change its batteries because they completely dead. Now when i turn the machine on no alarm appears tape load perfectly. But after that the system ready button do not activate.I see the system parameter it appears to be correct ( I do not know the right value) but optional parameter no.1 and no.2 do not show any thing they are blank. I think there parameter become corrupted. Could anyone help me to solve this problem.
Have you try reloading the software?
Sometimes when you change the batteries you miss some parameters...
Hi roswell28
yes, I think too that after changing the batteries I have lost parameter. I have tried many times to reload system. usually i use three tapes. One is erase, second is system 1 and third is system 2. fifth is e-pack. I do not know why there is not a fourth tape.did i missed the fourth tape.do you have dwc-90h. could you please tell me the parameters of system paramter.
Hi Buddy.
I have just 3 floppy disk, one is for E-Packs,other for Pitch Error and the last one have the version of the software of the machine (It could be D1 or E4).
Do you have the same disks? Do you have the right procedure to reload the software?
If you need more help please let me know.
HI!
I have four cassettes. As i have already told you that one is for erase and other two are for system load. One is for e-pack.I do not know where to find the machine software version? do you have dwc-90h? could you please send me the picture of your system parameter screen? I highly appreciate if you can.
hi all
ı have mitsubishi fx30k 2000 model.how ı can found e pack and offset for 0.25 wire latest version? thanks
See attached: hopefully this is enough to get you going.
Tech file is from FA20s
If you get invalid epack number error then subtract 1280 from the shown epack number
ie: 2051-1280=771 (E2051=E771) This is the epack difference between our FA and our CXs
Hope this helps
thanks Royster
You were very helpful in
Rosweell28 >>>
I have a 110HA model, maybe you could help me.
i have the T215 code alarm, that says: "SECUENCE ERROR"
this alarm becomes after a 10 min. aprox. working time , i re-start you know:
FLUID > WIRE > MACHINING > START
it works again about 3 min. and T215
again and again
HELP !
We have a '98 FX10.
On our machine the T215 error seems to be a generic error message. If you can be looking very carefully at the screen when the meesage comes on, it will very quickly flash a more specific error & then change to T215.
That being said, I asked my dept forman about your issue. He said that they had a similar problem & it was simply the water level. The first time was when we just got the machine & the tech who set it up had only partially filled the holding tank, after a couple of weeks, the water evaporated a little & when we filled the tank, the water in the holding tank dropped below the sensor.
My forman suggested checking water level, fiilters & perhaps clean the sensor in the tank.
Good Luck
Hello , I have four cassettes for FX30K. Are you still interested ?
cassette 1 BRD-B00W005A1 (1/3)
cassette 2 BRD-B00W005A1 (2/3)
cassette 3 BRD-B00W005A1 (3/3)
cassette 4 BRD-B19W050-A3 WEDM SYSTEM PROGRAM INGLISH
cassette 5 BRD-B93W364-A0 DATA I/O
cassette 6 PITCH ERROR AND BACK LASH
cassette 7 BRD-B13W019-A6 E-PACK
hello.......need some help with mi fx10wire i cant communicate with it,im using cimco edit with thes setings:
com1 stopbit 2 even
baudrate 2400 databit 7
sofware
am i way off...i need some help ,im new at thes and i realy dont have a clue.
ill buy you a beer
The settings we use for our computer are as follows:
Com 1 (this is the com port that you have the cable plugged into on your computer)
2400 Baud rate
even parity
7 databits
1 stop bit
if you cannot get the machine to receive with these settings you may have to reduce the baud rate, but you have to then alter the machines baud on machining data, RS para page.
thanks for the tip .................you were wery helpful.....
god speed
Dear guys,
In our company we bought machine Mitsubishi FX10 wire edm. We have problem when we turn on machine, on screen you can see System reload message.
Machine was before electrity maybe 7 days. Machine now ask me to put system floppy disk. My question is If somebody have floppy disks for this machine?? Thank you in advance
Do you have an FX10 or FX10K?
FX10 We have
