586,036 active members*
3,695 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Abrasive grinding/polishing wheel for cnc mill. Possible?
    Sep 2008
    83
    I wonder if there is some kind of tooling for a cnc mill to allow grinding and polishing?
    If there is can you please point me to the site or manufacturer from whom I can get it.
    Thanks!
    Jun 2008
    11
    I am looking for the same thing
    I am machining aluminum air cylinders and am looking for the same type of product. I have also been looking for something like a burnishing tool that can be run as a finisher on the walls, since my cylinders are not round a standard burnisher will not work. I am looking for any suggestions.
    Nov 2008
    129
    High frequency spindle for grinding
    Have you consider using a high frequency spindle or spindle speeder to give you the rpm: http://www.mctooling.com/index/listings/page862.htm
    Jul 2006
    58
    Are you thinking something along the lines of a rubberized abrasive wheel or stick? Such as:
    http://www.cratex.com/rubindx.htm
    It reminds me of the old electric drafting erasers. They used to have some eraser sticks with abrasive for erasing pen and ink drawings. Maybe they still do.
    Jun 2008
    11
    I got a hold of a company in Grand Rapids, MI called C.B. DeKorne that got me a bunch of samples of things to try, and I found that felt bobs work pretty good for polishing parts in a machine. As long as you apply some compound the walls of the part and program the bob to have about .01-.015 of side load. The other thing that I tried that worked fairly well was some little scotchbrite wheels that we ordered from J&L Industrial Supply. Those come in a variety of different abrasive levels.
    I hope this helps.
  1. Grinding Cam profiles on a DeskCNC 4 axis mill
    By Paraprop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2015, 06:16 AM
  2. cutting die to cut abrasive cloth?
    By Syphonics in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2008, 04:15 PM
  3. Turning A Grinding Wheel
    By drill in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-07-2006, 02:24 AM
  4. Grinding flat surfaces on vertical mill?
    By Cowbell in forum Benchtop Machines
    Last Post: 01-18-2006, 05:59 AM
  5. 5 axis Abrasive WaterJet
    By Lesh in forum MetalWork Discussion
    Last Post: 09-18-2005, 06:39 AM
