586,036 active members*
3,543 visitors online*
    Oct 2008
    Stepper Skipping Steps
    I'm new to the stepper motor world and I have a few questions. I work in electronics and I have access to lots of parts, so I built a controller/driver circuit using parts we have in stock. My stepper says it is rated at 5 Volts and 1 Amp. Measuring the winding they do indeed come out to be 5 Ohms. Right now I'm just experimenting, I have a variable frequency clock driving my circuit and I have an up/down switch so I can run it in either direction. Everything is working great at extremely low frequencies but after I get the clock up around 400 Hz I can tell that it starts skipping steps and if I go higher it will stop and just buzz not rotating at all. I looked up the specs of my motor on the web and each phase/winding (4 in all) has 8 mH of inductance. So with a little math, I find that the cut off frequency(where the inductive reaction equals the winding resistance) is 99.47 Hz. So it looks like I'm going to have to run the clock at less than 400 Hz. What bothers me is that the motor rotates 1.8 degrees per clock pulse and requires 200 pulses to make one revolution. That means that the fastest that I can run this is 2 turns per second. If that is driving a 18 tpi actuator it would take 9 seconds to move 1 inch. Am I missing something here? Are the CNC's really that slow? Is it my motor? I am switching only 5 volts and I could run a higher Voltage with a resistor or better yet a one amp constant current source to try to overcome the inductance. Does anybody have any experience with this? How fast are you guys rotating your motors? Any thoughts would be greatly appreciated.
    Steve
    Jan 2006
    738
    Is your motor connected to anything while testing? Could be you are seeing mechanical resonance causing the issue. Try attaching a load to it, or just a sizable flywheel and repeat the test.
    Steve
    May 2008
    110
    If I understand right you are trying to run your motors on 5volts, you need to run these motors on at least 24 volts
    budP
  1. Skipping Line Code???
    By bvweld in forum DynaTorch
    Last Post: 09-24-2008, 06:16 AM
  2. What causes a stepper motor to jump steps
    By erkiwi in forum Stepper Motors / Drives
    Last Post: 02-20-2008, 08:26 PM
  3. Losing Stepper Steps Help Needed
    By halmande in forum DNC Problems and Solutions
    Last Post: 02-12-2007, 12:56 AM
  4. Deskcnc Skipping Lines Of Code
    By bradyfb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2007, 11:59 PM
  5. Losing X steps, stepper to small??
    By matth in forum DIY CNC Router Table Machines
    Last Post: 09-06-2006, 06:48 AM
