Hello, new to the forum! I have more of a thermal question, but couldn't find a proper place to put it, I apologize if this is the wrong place to pose this question.
I am building a DIY Class A amplifier, that will be water-cooled. The Aluminum block is 3"x"3 @ 12" length. I am not an engineer, so go easy on me. I've attached a pic to describe what I'm trying to achieve here. The block will be run to a radiator out of a 190Hp gas vehicle with two large fans providing the cooling, and of course a water pump. I am trying to figure out the °C/W of the block at various flow rates ie 1, 1.5, 2, etc in Gallons Per Minute. My hope is to dissipate up to 1300-1400 watts, and keep the Mosfets at roughly 75-80C junction temps. There will be 12 Mosfets attached to the block, 6 on top, 6 on the bottom. The materials used are whats on hand to build this cheaply; advice and design change if necessary would be helpful.
regards-
John
