so the z-axis brake is used only when the machine is powered off?
yes. Only to hold it in place when the servo is not powered or when emergency stop is pressed.
We displayed the machine at the Las Vegas at the wood working show last week and it did VERY well. We took orders for 6 machines :cheers: I was very pleased to say the least. Retail at $49,000. helped too. I have 2 more coming in September. I changed the drive system and removed the belts all together. Rotating the rack and pinion 90 degrees to allow the motor to stand straight up on all axis will make a huge difference. I'll send photo's of them when I get them in
Cheers
Kirk
Congratulations, it's a good looking machine and it seems you have a nice price as well.
Thats good news! - would be real interesting to see the alternative to the belts
hi, great-looking machine, I'm starting to build something similar myself. I have a 16HP Colombo ATC spindle, and will be making the tool change mechanism myself- how did your ATC work out?
cheers
Hello steve p,hi, great-looking machine, I'm starting to build something similar myself. I have a 16HP Colombo ATC spindle
What is your reason to use a big 16HP Colombo ATC spindle? Is that not enough to use 1.5 hp spindle to cut wood? Or you will also cut alot of metal. Tx.
I have one question. I have atc spindle with two air connections for piston to release or clamp tool and one for taper clean. On first one it says piston delivery, on the second one piston retract on third one taper clean. Which solenoid valve I need 5way, 4way or 3way and how many of them?
I'm no expert, but I wanted a larger spindle to increase the feed rates so 2.5 or 3D jobs didn't take forever, it means you can push harder and cut much faster without losing edge quality since the rotational speed is maintained. I was looking for something around 10hp- it seems most gantry-type routers made for a professional environment are around that size, but this 16hp ATC one came up at the time. I do cut quite a lot of ali, so I suppose I will be able to cut thicker in one pass, which will be a help too.
I now have also bought a bunch of used servos (Allen Bradley 2.5kw a.c. units) and a set of matching new drives (AB Ultra3000s). I know you're not supposed to do it this way round (you should calculate the required motor torque+speed from the machine specs), but seven motors and four new drives with all cabling for under a grand seemed too good to miss... I noticed that the mach3 manual has a section on motors and gearing, I'll read that shortly, but if anyone had any links to good reading in this area I'd be grateful.
Kirk nice machine,nice price.I use a $ 100K machine similar design as far as the base tubes.Are you sure you used 3/4" wall or was that a typo error?My machine has 3/16"tubes.I think my machine is 8,000lbs or so.Your machine must be heavier than this.
The 10to1 gear boxes and 2to1 belt pulleys are a good setup.In the event of a crash,something has to give.The belts may be insurance as they will break before the gear boxes or rack.Something to consider with the high rapids.
Keep up the good work:
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Hi Steve,
I bought aluminum tooling pockets and bolted them to a rack. I will get some pics and post a video of it in use tomorrow.
Thanks !
Kirk
Hi Steve,
Sorry about the delay here is a quick snap shot of the rack.
Thanks !
Kirk
I like how you have the y axis motors tucked way with your gear box,
what the ratio you have set up there? do you have a close up of your
pinion alignment for your y axis and the pillow block using the spit pinion set up?
