Originally Posted by
Eclipze
The limitation of the CNC is the maximum acceleration before the machine flexes (only a small machine). So if I stop with a deceleration of 500, it stops perfectly, but the momentum energy dissipates as a little bit of machine flex from the sudden stop. When this happens running the 3D milling code, it produces a shuddering noise around tight corners, though will reach maximum feedrate where straight sections are machined. The shuddering causes slightly more machining marks on the surface of the material.
