586,080 active members*
3,715 visitors online*
Results 1 to 6 of 6
    Oct 2005
    278
    Unhappy Mach3 MPG Setup...losing mind...requesting help...
    hey everyone!
    I have the cnc4pc pendant seen here-
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=158
    and the card seen here-
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=159
    I have a pci card for my second parallel port and windows says its functioning fine. windows says that the I/O range is DFF0-DFF7 and underneath DFE0-DFE7
    Does this mean that my "port 2" in mach should be "0xff0"???
    Also, my port 2 is enabled and the 2-9 pins are checked as imputs.
    I have the MPG connection card pluged into the new pci parallel card in my desktop and the MPG pluged into that. I have the card power plugged into a spare usb port for the needed 5v.
    I downloaded the brains from cnc4pc and installed in the correct folder.
    I followed the instructions here-
    http://cnc4pc.com/Tech_Docs/guide_fo..._over_LPT2.htm
    to the letter! all the selections for ports/pins etc have been duplicated exactly.
    I have made sure that jog mode is selected to "on" on the mach 3 mill "program run" screen.
    I am now totally stumped. I dont know what im doing wrong.
    I do have a http://www.cnc4pc.com/Store/osc/prod...roducts_id=161 board installed. but its not actually controling anything yet. just hooked up to act as an optioisolation failsafe.
    Any help you guys can provide will be appriciated.
    Nate in Meechigan...
    Nate.
    Ann Arbor Meechigan
    Set your port 2 to "DFF0".
    Oct 2005
    278
    Hello again!
    I actually tried that last night. To no avail...
    Any chance you know which Brain should be activated in mach3?
    I am startig to suspect that my ports/pins and associated settings are wrong. unfortunately, i dont know how to work them out from scratch.
    p.s. I just sent you a PM. right as you were posting your reply...lol
    Nate.
    Ann Arbor Meechigan
    You shouldn't have any Brains activated, I don't think. You need to make sure the port is working first. The easiest way is to set up an output on the second port, turn it on and see if you get 5V at that pin.
    Oct 2005
    278
    ahhh thats how to check to see if the port is connected and functional!
    Nate.
    Ann Arbor Meechigan
    Or set it up as a direction pin, and jog back and forth and see if it toggles from 0 to 5V.
  1. Losing mind. parallel card/mach3/xylotex... please help!
    By nate in forum CNC Machine Related Electronics
    Last Post: 06-08-2008, 02:51 AM
  2. Losing steps with Mach3
    By CMPM in forum Mach Plasma / Laser
    Last Post: 07-20-2007, 04:02 PM
  3. Mach3 setup
    By mlaws1172 in forum Mach Plasma / Laser
    Last Post: 11-30-2005, 05:14 PM
  4. New Taig in mind help on setup please
    By mdoan in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2004, 08:16 AM
