586,108 active members*
3,073 visitors online*
    Aug 2008
    13
    Feed rate and rpm's
    Can anyone help?
    We are new, new new to using a CNC machine.
    We are in the process of trying to cut 1/2" OSB board and cannot get the feed rate and spindle rpm's down. We have already broken 5 bits. Can anyone give us some good starting point on the feed rate and rpms we should use?
    Larry
    What size bits? It's very difficult to break a bit unless your rpm and feedrates are way off, unless your using 1/8" or smaller bits.
    What is your tool size and type? Feedrate? RPM? Depth of cut?
    Aug 2008
    13
    We were using a 1/4" bit. and were trying different rpms and feed rates. We at first tried to cut through on one cut but then went to 1/2 trying different speeds then just gave up.
    Try full depth at 17,000 rpm and 150ipm. I'm assuming you're using a solid carbide spiral bit? Carbide tipped 1/4" bits aren't nearly strong enough to hold up for long.
    Aug 2008
    13
    Thanks Gerry will try it.
  1. Feed rate for 5/8-18 tap
    By Eagle View in forum MetalWork Discussion
    Last Post: 09-24-2008, 03:25 PM
  2. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  3. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
  4. Feed Rate?
    By bearwen in forum Uncategorised CAM Discussion
    Last Post: 04-26-2006, 10:52 PM
  5. How can I up my feed rate ?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-13-2004, 03:40 AM
