586,216 active members*
3,694 visitors online*
Results 1 to 8 of 8
    Mar 2006
    107
    G1 with R (Fanuc 0-MC)
    I have one machine which appects that (G1 R<number>) and other one doesn't accept. Actually no alarm pops out but it makes sharp corner without radius.
    Both machines have Fanuc 0-MC.
    I have found some old thread with same problem but it hadn't been solved.
    Sorry for bad english
    Post your part program
    L. Sakthivel
    Email:[email protected], website:www.premierengrs.com
    Mar 2006
    107
    Here it is
    Code:
    G0 X9.50 Y-27.40
    G0 Z-9
    G1 X-212.69 F500
    G2 Y6.20 R17.20
    G1 X6.20 R20
    G1 Y-29.55
    But, there should not be problem in program, because 100% same program on one machine works and on other doesn't.
    2932
    Looks like a decimal point problem. Have you tried R20. in that block?
    I would compare parameter 0015 bit 7 and 0016 bit 3 on both machines. Make the one that doesn't work the same as the one that does.
    G01 is the Linear interpolation only try G02 in place of G01
    L. Sakthivel
    Mar 2006
    107
    0015#7 = 1 on both machines (If a decimal point is omitted, the selected unit is the least input increment / mm, inch, deg, and sec.)
    0016#3 = 0 on both machines (Decimal point input or display is used / is not used)
    I knew that it is not problem with decimal point because I know that machine interprets numbers without decimal point as milimeters.
    Any other ideas?
    Maybe there is a parameter to enable this, but it might be 900's parameters which I don't have in my param. book???
    Dec 2019
    Lightbulb Re: G1 with R (Fanuc 0-MC)
    well this is waaaaaaaaaaaaay too late but i think you need to put "," before so it goes lie=ke this
    G0 X9.50 Y-27.40
    G0 Z-9
    G1 X-212.69 F500
    G2 Y6.20 R17.20
    G1 X6.20 ,R20 <-----
    G1 Y-29.55
    just for info if someone else had the same problem
    Nov 2007
    352
    Look for Parameter for Circle intrpolation
    One is for an R value and the Other will be for I/J/K
  1. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
  2. Replies: 7
    Last Post: 11-17-2013, 01:46 AM
  3. Replies: 10
    Last Post: 03-02-2013, 05:00 AM
  4. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
