586,438 active members*
4,070 visitors online*
    Aug 2008
    10
    Exclamation Starting program in fanuc 6m
    Hi
    I just installed a 1981 yasda YPC 45 machining center. The machine is in mint condition.
    Anyways here comes the problem.
    When i fire up the machine everything seems fine. I do atc chek and table ready. I set the mode to MDI go to COMND move a page down, to start a block. I punch the desired code and press INPUT.
    When it is done (and here`s the pickle) i press start and nothing happens.
    I`ve tried everything i can think of i`ve turned the machine on and of sevral times. But sudenly this morning, when i turned the machine on it worked.
    I used the machine for some time and turned it of.
    When i some time later turned it back on again it`s same old same old.
    That said i have no experience with fanuc controll what so ever.
    So i might have got something wrong from the start. But i`ve read the user manual and can`t see that i have.
    Anyhow any suggestion why this could be.
    24223
    In MDI did you enter EOB end of Block?
    Does the START light come on?
    No end of Block, no START light.
    If START light, then program is hung up on a command.
    Al.
    Albert E.
    Aug 2008
    10
    Sorry to say Al either i din`t get when to press EOB or it didn`t work.
    (The first reason is probably the best explanation.)
    But since i didn`t press EOB in that glorious moment it actualy worked.
    I suspect something else to be the reason.
    I do suspect a slightly defect start button. But i also suspected every other button to be defect intill i knew how to use them
    And you mentioned a start lamp i can`t really identify one.
    PS: i added some screenshots. maybe some of you who has seen how the scrren shuld look like kan identify if you see something suspicious.
    Attached Thumbnails Attached Thumbnails Bilde071.jpg   Bilde072.jpg   Bilde073.jpg
    24223
    EOB is a button and a semi-colon is entered at the end of a line before ENTER.
    Usually the MTB puts a light in the Cycle-Start P.B.
    To test the buttons you can go to the diagnostic page and look at the inputs to see if one changes from 0 to 1 when pushed.
    Al.
    Albert E.
    Aug 2008
    10
    Talking
    Problem solved.
    A wire for one of the safety buttons where eroded.
    Always and never are two words you should always remember never to use.
    W.J
  1. problem starting up FANUC
    By gisbertz in forum Fanuc
    Last Post: 05-30-2009, 09:14 PM
  2. Starting in the middle of a program.Old control.
    By lostkoss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-07-2008, 03:11 PM
  3. Replies: 2
    Last Post: 06-30-2008, 09:54 PM
  4. fanuc program comments
    By Rich 72 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-04-2007, 01:38 PM
  5. FANUC 6M Program format
    By Moolvie in forum Fanuc
    Last Post: 10-08-2005, 03:37 AM
