586,036 active members*
3,789 visitors online*
    Oct 2008
    23
    Unhappy MAHO-PHILIPS 432 M60 and G23 problem
    Hi, I have a little problem....
    I have a MAHO MAT 550 model milling machine with 2 pallet.
    Whe I try to change the pallet I have:
    N10002 (PROGAM NUM.)
    N39 G0 Z200
    N40 M60 (change)
    N41 G23 N=10003 (jump to program)
    and the other program finish with
    N10003
    N25 G0 Z200
    N26 M60 (change)
    N27 G23 N=10002 (jump to program)
    but the CNC stop for an error because there are 2 G23.
    I need help to jump between 2 program, one program in the pallet A, when finish change to pallet B that change to A and more....
    The only system that I found since today is to finish the first program with M30 and after the finishing of the second program the machine STOP and I have to push the start button.... but it is a loss of time
    MANY THANKS
    Mar 2007
    64
    What you need to do here is load the programs that cut your parts into
    (MM) macro memory.
    In your main program memory (PM) you have a program that makes the pallet change and then calls the macro program to be executed. The macro call is done with a G22. Your programs in macro memory need to have the M30
    as the last line. When the M30 is read the program control will then return to the main program. In the main program, make the pallet change to the second part and make a macro call G22 for the second part. You can loop the main program as many times as you like with a G14 N1=xxx N2=xxx J= xxx.
    Oct 2008
    23
    Hi... I try many way bu the only one soluction that I found is:
    N3 E1=1
    N4 G29 N=10001 (first program)
    N5 M60 (palette change)
    N6 G29 N=10002 (second program)
    N7 M60
    N8 G29 E1 N=4 (jump to line N4)
    N9 M30
    The only one problem is that the variable E1 is the utensil life...
    In this moment I don't use this function.... but in the future....
    The command G29 don't work if the utensile life is 0.
    I don't wont to use the macro memory because the singol program (es. 10001) I can use it in a "stand alone" method
    Mar 2007
    64
    Try this if you do not want to use MM
    Quote Originally Posted by micktat View Post
    N3 E1=1
    N7 M60
    N9 M30
    Mick I have never used a G29 the way you are using it but if that works for you then .......
    ADD TO LINE N8 "K0" .
    The K0 tells the control to reduce the E word by 0 so the value of E1
    remains 1. The skip is only done if the E value is > 0.
    A reduction of 1 is the default if there is no K word on the G29 line.
    G29 works like a FORTRAN IF statement:
    IF the E word is > 0 the skip is carried out
    IF the E word is < = 0 then no skip is carried out
    N3 E1=1
    N7 M60
    N8 G29 E1 N=4 K0 (jump to line N4)
    N9 M30
    Hope this helps!
    Mick,
    Do you have a programing manual? If not I may be able to get you one.
    take care and have fun
    Oct 2008
    23
    Hi, thanks...
    But I read the instuction on the manual but I think that the K0 is not necessary.
    The program works good, only I don't know what it make if I use the Tool life.
    Thaks
  1. Maho graziano-philips controll unit
    By coco5 in forum Uncategorised MetalWorking Machines
    Last Post: 08-16-2019, 05:29 PM
  2. Maho GR300C with Philips controller
    By marid in forum Controller & Computer Solutions
    Last Post: 08-23-2008, 11:24 AM
  3. Maho GR300C with Philips controller??
    By marid in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-22-2008, 10:19 AM
  4. Maho 650 - CNC 532 Philips
    By nylas in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2007, 07:41 PM
  5. Is a Maho MH400E with Philips 432 a good buy ?
    By karlis_m in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-06-2006, 01:28 PM
