586,116 active members*
3,474 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Spindle stop (M5) and coolant off (M9) by Reset button (0-MC)
Results 1 to 11 of 11
    Mar 2006
    107
    There must be some parameter(s) for that, because same controll (0-MC) on two machines, on first one Reset button stops spindle and turns coolant off, and on the other machine, it doesn't.
    I have parameter book but I can't find anything.
    Sorry for bad english
    Feb 2007
    314
    I'm not sure, but take a look at prm#45 bit 6
    1:selects clear conditions using reset button
    0:selects reset condition using the reset button
    I have no detail about what are clear and reset conditions but if this parameter is not set at the same value on both control, maybe it is the cause of your problem.
    p.s. My english is worst than your
    Mar 2006
    107
    On both machines 0045#6 = 1 (clear state)
    2932
    My guess is that's part of the ladder. There may be a Keep Relay that lets you select it.
    Sep 2005
    767
    dcoupar is right. The spindle and coolant outputs are controlled in the ladder, so it would not have a conventional parameter. Don't mess with #0045 bit 6. That will change how G-codes are reset, which you don't want to do.
    Mar 2006
    107
    I know what #0045 bit 6 is, actually I have changed it when the second machine came to me so it is now equal on both machines.
    If it is defined in ladder, it could not be changed? Maybe there is some D adress (DGN) which keeps it on.
    2932
    Perhaps if you told us what make/model of machine it was, maybe someone here has one with a list of keep relays.
    Mar 2006
    107
    It is KIA KV25P from 1995.
    But i doubt that any one here has experience with this machine
    Aug 2006
    98
    Padobranac,
    Try change D109#5 to 1 to stop spindle rotating and coolant.
    Daniel
    Mar 2006
    107
    Thanks, I'll try it when I came to machine.
    Mar 2006
    107
    I am not able to change D109#5 even if I am on MDI and PWE=1 and key is on write.
    I have found in ladder some R adress which is called "RESET M CODE" but i can not affect on execution of it.
  1. E-Stop Button
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 05-19-2008, 08:41 PM
  2. Changing screen size or a keyboard trigger for the reset button
    By maxboostbusa in forum Mach Software (ArtSoft software)
    Last Post: 03-16-2008, 07:54 PM
  3. automating the gecko reset button on power up
    By Chris64 in forum Gecko Drives
    Last Post: 02-27-2008, 09:58 AM
  4. On an OT control, hitting the reset button
    By g-codeguy in forum Fanuc
    Last Post: 06-14-2007, 05:21 AM
  5. Help with e-stop button
    By Astroguy in forum Xylotex
    Last Post: 05-31-2007, 01:23 PM
