586,872 active members*
4,852 visitors online*
IndustryArena Forum > CAM Software > OneCNC > 3d solid from wireframe
Results 1 to 9 of 9
Hybrid View
    Aug 2007
    I am trying to make a solid from imported dxf wireframe with no sucsses,
    can anyone explain what steps should I take ?
    using one2000 miill pro.
    Attached Files Attached Files
    Apr 2007
    243
    Thumbs up
    You can't that is a dxf mesh file. You need less line to use as boundaries for a skin or something like that.
    You DXF was a very simple shape. I would just redraw it from the start in the software.
    Regards,
    Dec 2008
    4548
    Impossible???NO!
    Practicle????NO!!!!
    You'de be better off just drawing it in your package. Poly modelers dont make good Cam Models.
    4826
    In OneCNC, you can import an stl mesh file and machine it. But there is no way to make the stl into a solid model in OneCNC, because, I suppose, doing so requires accurate data about surface boundaries which the stl does not contain except in the form of each triangle. You'd need different algorithms to convert stl into some sort of a solid, and even then it would only be a guesstimate of the original model's true design. OneCNC makes no apologies for being a NURBS based surface modeller, because that is part and parcel of their development intentions.
    Apr 2007
    243
    Exclamation
    That has nothing to do with what we are talking about.
    He needs to profile the shape, and you can't extract a 2D wire frame boundary from an STL mesh in BobCAD. I am sure that you can't do it in onecnc either.
    He could do a Z level finish, but in most cases you would want more control over how you are cutting and because it's just a 2D profile you would want to use cutter comp ( G41/ G42 ) which Z level finish doesn't have.
    4826
    The original poster said nothing about how to machine it. He asked about turning it into a solid model. That is why I explained that it cannot be done in OneCNC because it does not have the functions for that.
    Apr 2007
    243
    Wink
    Sorry about that, you're right. And we both agree. I guess I was looking deeper into the questions. Why would you want the file as a solid? I believe which I may be wrong, he wanted to machine the part and though that it needed to be a solid to do so.... I am not sure.
    But either way I know you have lots of answers and are very good with software.
    Talking
    Hello, thought I would add my 2 cents here in the hopes that it may be of assistance.
    1.) You can load an STL into OneCNC, save as IGES, Step, SAT Etc, then load back into OneCNC. You will find that all of the edges have loaded as lines. However, don't look for arcs, please remember, STL files are triangular meshes. Having said this, arcs can then be easily created via fillet or through existing points.
    2.) You can also load an STL into OneCNC and create lines, points, construction planes Etc from the native STL verticies. Arcs can then be created via fillet or through existing points. In fact, anytime OneCNC provides a snap to "EndPoint" option, you can use native STL verticies.
    Hope this was of assistance!
    Best Regards
    OneCNCWest
    Apr 2007
    243
    Yes that was very helpful. So you can save out an STL as an IGES and OneCNC will convert it to surfaces. That's cool. Then you can extract the wire frame and use it to create a series of curves ect.
    Do you have a feature that converts a series of line segments into arc segments. Like an arc fit feature?
  1. Making a solid out of a wireframe
    By keebler303 in forum Solidworks
    Last Post: 06-20-2008, 09:38 PM
  2. 3D wireframe creation
    By brockadeau in forum BobCad-Cam
    Last Post: 02-01-2008, 03:42 AM
  3. Solid to wireframe HELP
    By Clawsie Machine in forum Mastercam
    Last Post: 05-22-2006, 04:10 PM
  4. 3D Wireframe to 3D Solid. How is this done?
    By Beezer in forum Autodesk
    Last Post: 07-23-2005, 04:15 AM
  5. 3D wireframe surface
    By JW Peters in forum Autodesk
    Last Post: 05-10-2005, 01:23 AM
