hi, I problem with electrical onload, my machine is mitsubishi DWC90H, it does not have power to cut anything, someone can help me? thanks/victor
Have you ever run an EDM before? There are 3 things to remember about EDMing.
1. Flushing
2. Flushing
3. Flushing
You must keep the dielectric in the cut in order to do any burning!
How is your set up? Does the machine have power to the head in the burn mode?
Give us more information on your situation. Has this machine worked in the past?
Victor your answer unfortunately does not make sense. Is this Mitsubishi Wire EDM machine located in the US, Mexico or Canada? If it is and it is registered with us you can always contact MC Machinery Systems at 630-616-5900 and we will assist you.
Si usted es un orador español escoge por favor opción 6 y usted será conectados con alguien que puede ayudar usted en su idioma
check 15v dc on dc unit or check all power supply
Could anyone help to check my dwc90h parameter. It start fine but system ready button do not operate. I think there is some parameter problem.
you should check alarm, no need change the parameter, because it's locked.
try press reset twice
I have tried everything. Could you people send me the picture of system parameters. which come when h1000 paramter is equal to 00000000100 and
m2.press twice input. after that the screen come.could you take the picture of this screen and option parameter 1 and 2 and send it me?
Hi
I have the picture of my machine parameter. could any one compare it
with his own machine.Can anyone tell me the difference. I am uploading the pictures.
There are some values here before machine got problem.
Please could any one give me atleast the picture of his/her machine of this view?i will update my parameter from the picture.
