586,446 active members*
3,792 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > G99/G98 in peck drilling cycle
    Sep 2006
    136
    Hi all,
    I'm having fun with posts again, a VMC this time.
    I'm using a pecking cycle, a G83, and my output is giving me this:
    G83 G99 Z-5.75 Q1.0 R10.0 F0.05
    All good, except I may want the G99 to be a G98. I can't for the life of me find a switch anywhere in edgecam to change it.
    How do I get to output:
    G83 G98 Z-5.75 Q1.0 R10.0 F0.05
    It's got to be there somewhere, but I can't find it. The token is [RETRACTGCODE]
    Mar 2006
    1013
    Make sure your Clearance value and the Retract value for your toolpath is the same and you'll get G99.
    It's not the post.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Oct 2003
    127
    i replaced the g99 with g98 so it always kicks out the 98 no matter what.
    in the hole cycle g-codes i made both return to initial level and return to r plane both 98.
    i don't do large run production so the difference between .05 and 1.0 in between holes at 1400 rapid doesn't mean anything to me and 1.0 feels safer to me.
    but mike is right how you fill in the clearance and retract will determine which kicks out.
    i think if you don't put anything in retract you will get G98
    May 2004
    142
    GET IN THE CODE CONSTRUCTORS...
    DONT MIND MY SPELLING ... IM JUST A MASHINIST
    Sep 2006
    136
    ah ha, thanks very much. It's always fun building a post - was that something I did, or the post did....?
  1. peck tapping cycle
    By jdsmith0524 in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2006, 05:36 AM
  2. fanuc -om peck cycle
    By PETE1968 in forum Fanuc
    Last Post: 04-06-2006, 03:57 AM
  3. Peck drilling
    By LarryMiran in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-23-2004, 11:12 PM
  4. G83 peck Drill cycle
    By Vaughan in forum G-Code Programing
    Last Post: 03-19-2004, 06:11 PM
