586,100 active members*
3,034 visitors online*
IndustryArena Forum > CAM Software > CamBam > single part selection from drawing
    Mar 2007
    50
    If I want to select a single part drawing from a multi-part file drawing in cambam how do i do it and then create the g-code from it. IE ( shark.DXF)
    I want to select just a single body from that file drawing and creat the g-code file from that selection only. Or any multi-part drawing for that matter... thank you guys so far you guys have been very helpful....
    Aug 2006
    24
    Select the part
    Create a MOP (profile, engrave, pocket etc.)
    Right click on the MOP and select Generate Toolpath
    Right click on the MOP and select Create Gcode File.
    Save g-code file.
    If the part requires more than one MOP, then right click on Machining in the tree view and select Create Gcode File, then save.
    Mar 2007
    50
    Thank you very much, Im going to try that. again you guys are very helpful
  1. Replies: 12
    Last Post: 10-07-2008, 12:08 PM
  2. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
  3. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
  4. Part->Block->Drawing-> Dimension
    By cncuser1 in forum Solidworks
    Last Post: 11-26-2007, 09:22 PM
  5. Is making a part as easy as drawing it in 3d?
    By randyf1965 in forum Commercial CNC Wood Routers
    Last Post: 04-05-2006, 01:23 PM
