586,102 active members*
3,106 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Looking for FANUC 0-T Operator Manual
Results 1 to 17 of 17
    Mar 2006
    Thank you
    24221
    PM sent
    Al.
    Albert E.
    Mar 2008
    4
    Al the man i also am looking for a faunuc manual could you possibly let me know were i may get such as well
    Jun 2008
    1511
    laserman send me a PM with your email and which one you need.
    Stevo
    Oct 2008
    5
    Looking for FANUC 0-T Operator Manual too.
    Jun 2008
    1511
    Send me a PM with your email
    Stevo
    24221
    I guess your need are taken care of...
    Al.
    Albert E.
    Oct 2008
    5
    Quote Originally Posted by stevo1 View Post
    Stevo
    I sent my E-Mail, thanks.
    Aug 2011
    12
    hi Stevo
    I am looking for FANUC OTT book, do you have this? This control is on 1992 PUMA 10S double turret.
    thanking you
    Stan
    Dec 2008
    239
    Sir FANUC TT means Double Turret please send a mail with your E mail so i can send it to you regards, [email protected]
    Jun 2008
    1511
    Stan,
    Which book are you looking for? Programming, parameter, maint?
    Let me know if your prabhat can't get you all of what you need.
    Stevo
    Aug 2011
    12
    hi Stevo1
    thank you, at this moment, I have nothing from yours prabhat. I need programming book, please. I need also help: I bought this machine used and am just starting to set it up and I made some mismatch by running and old program inside and I have failure: "not ready" and program running . I cannot reset system!! what can I do?
    thanking you, have a nice day
    Stan
    Sep 2006
    94
    O-TT
    I also could use the Fanuc O-TT manual. I have a Star CNC 32 that has some alarms I can't figure out.
    Heath
    Dec 2008
    239
    FANUC OTT
    Dear Friends,
    i can not Upload the Manual here If you are in Need send a mail with your E mail address.
    Do not ask Like I did not get anything.You are looking NOT ready While Program is running It may be due to The force Bye pass of interlock, Please say the details about the machine So we can help you.
    warm Regadrs
    Prabhat Mishra
    Sep 2006
    94
    yours_prabhat, I have sent you an e-mail.
    My machine is a Star KNC 32 running a Fanuc O-TT.
    Alarm messages are:
    Head 1: O4044 N0002
    No. 2000
    Emergency Stop
    Head 2: O1820 N1820
    No. 2000
    Emergency Stop
    Dec 2008
    239
    ALARM 2000
    Sir,
    the Alarm 2000 Emergency Stop is an external Alarm not a system Alarm , Please check through the ladder The Emergency circuit, Like = Hyd or Pneumatic pressure Sw, Turret Clamp, Gear Pos sw, Etc Etc.
    Hope you will do it If Problem persisits, Please communicate me on [email protected]
    Regards
    Prabhat Mishra
    Dec 2008
    239
    Dear All,
    Here are some basic ALARM DETAILS for FANUC
    Alarms Fanuc Alpha Servo Drive
    1 :Over-voltage alarm (HV)
    2 :Low control power voltage alarm (LV)
    3 :Low DC link voltage alarm (LVDC)
    4 :Regenerative dis-charge control circuit failure alarm (DCSW)
    5 :Over-regenerative discharge alarm (DCOH)
    6 :L-and M-axis over-current alarm (HCM)
    6. :L-and M-axis IPM alarm (IPMLM)
    7 ynamic brake circuit failure alarm (DBRLY)
    8 :L-axis over-current alarm (HCL)
    8. :L-axis IPM alarm (IPML)
    9 :M-axis over-current alarm (HCM)
    9. :M-axis IPM alarm (IPML)
    AlarmsFanuc Alpha Spindle Drive
    AL-01 : MOTOR OVERHEAT
    AL-02 : EX SPEED ERROR
    AL-03 : FUSE ON DC LINK BLOWN
    AL-04 : INPUT FUSE/POWER FAULT
    AL-05 : POWER SUPPLY FUSE BLOWN
    AL-07 : OVERSPEED
    AL-08 : HIGH VOLT IN-PUT POWER
    AL-09 : OVERHEAT MAIN CIRCUIT
    AL-10 : LOW VOLT IN-PUT POWER
    AL-11 : OVERVOLT POW CIRCUIT
    AL-12 : OVERCUR-RENT POW CIRCUIT
    AL-13 : DATA MEMORY FAULT CPU
    AL-15 : SP SWITCH CONTROL ALARM
    AL-16 : RAM FAULT
    AL-18 : SUMCHECK ERROR PGM DATA
    AL-19 : EX OFFSET CURRENT U
    AL-20 : EX OFFSET CURRENT V
    AL-24 : SERIAL TRANSFER ERROR
    AL-25 : SERIAL TRANSFER STOP
    AL-26 : DISCONNECT C VELO DETECT
    AL-27 : DISCONNECT POS-CODER
    AL-28 : DISCONNECT C-POS DE-TECT
    AL-29 : SHORTTIME OVERLOAD
    AL-30 : OVERCURRENT POW CIRCUIT
    AL-31 : MOTOR LOCK OR V-SIG LOS
    AL-32 : RAM FAULT SERIAL LSI
    AL-33 : SHORTAGE POWER CHARGE
    AL-34 : PARAMETER SETTING ERROR
    AL-35 : EX SETTING GEAR RATIO
    AL-36 : OVERFLOW ERROR COUNTER
    AL-37 : SPEED DETECT PAR. ERROR
    AL-39 : 1-ROT Cs SIGNAL ERROR
    AL-40 : NO 1 ROT Cs SIGNAL DETECT
    AL-41 : 1-ROT POSCODER ERROR
    AL-42 : NO 1-ROT. POSCODER DETECT
    AL-43 : DISCON. PC FOR DIF. SP. MOD.
    AL-44 : CONTROL CIRCUIT(AD) ERROR
    AL-46 : SCREW 1-ROT POSCOD. ALARM
    AL-47 : POS-CODER SIGNAL AB-NORMAL
    AL-49 : HIGH CONV. DIF. SPEED
    AL-50 : SPNDL CON-TROL OVER-SPEED
    AL-51 : LOW VOLT DC LINK
    AL-52 : ITP SIGNAL ABNORMAL I
    AL-53 : ITP SIGNAL ABNORMAL II
    AL-56 : INNER COOLING FAN STOP
    AL-57 : EX DECEL-ERATION POWER
    AL-58 : OVERLOAD IN PSM
    AL-59 : COOLING FAN STOP IN PSM
    Fanuc Alpha Power Supply Fault Code
    AL-01 The main circuit power module (IPM) has detected am Error (PSM-5.5,-11) Overcurrent flows into the input of the main circuit (PSM-15 to –30)
    AL-02 A cooling fan for the control circuit has stopped
    AL-03 The Temperature of the main circuit heat sink has risen abnormally
    AL-04 In the main circuit the DC voltage (DC Link) has dropped
    AL-05 The main circuit capacitor was not recharged within the specified time
    AL-06 The Input Power Supply is abnormal (open phase)
    AL-07 In the main circuit the DC Voltage at the DC link is abnormally high
    [email protected]
    Regards
    Prabhat Mishra
  1. Meldas MO operator manual
    By cut more in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2013, 07:16 PM
  2. Need Operator manual
    By areofab in forum Want To Buy...Need help!
    Last Post: 11-07-2008, 08:43 AM
  3. MAZAK V10N FANUC 6MB OPERATOR MANUAL
    By RGD in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-17-2008, 03:28 AM
  4. CNC/Manual Machinist/Operator Needed!!
    By bugzpulverizer in forum Employment Opportunity
    Last Post: 07-10-2008, 09:09 PM
  5. Cnc/manual Operator & Programmer In North Nj
    By elaganis in forum Employment Opportunity
    Last Post: 08-03-2006, 01:17 AM
