586,640 active members*
2,424 visitors online*
IndustryArena Forum > CAM Software > CamBam > moving a part in the cambam field
    Mar 2007
    50
    Another very basic Question with cambam, and that is how do you move an object or part to be milled or engraved, around to different areas of the cambam field how do you do it. when I do a gcode on a drawing it sends my router to where the part was saved at, or the gcode is created frome where the part was drawn from. IE ( shark,Trex, files) I want to move them and then create the gcode from there.
    my field of routing is small,
    Aug 2006
    24
    For CamBam version 0.802,
    Select the object to move
    Open the Transformation matrix
    Select Transform from the drop-down list
    Select the axis along which you wish to move the object
    Input the distance (in units of measurement that you are using i.e. mm or inches) A negative number for X will move to the left, a positive to the right. A negative value for Y will move down the screen, positive will move up.
    Click Apply
    Click OK
    On the menu bar at top of CamBam screen,
    Select Edit->Apply Transformations
    When warning dialogue box opens, select OK.
    For the later versions of CamBam, simply hold down the shift key, select the object, and drag and drop.
    Mar 2007
    50
    Thank you so very much Bertram. You dont know how much you have helped me with the information you have given me. I am trying to learn Cambam while I am getting my cnc router setup to try to run a program. to try it out engraving something. I hope to return the favor sometime....
    Aug 2006
    24
    You are very welcome.
    Have you found these pages yet?
    http://www.cambam.co.uk/docs/tutorials.html
    http://www.cambam.co.uk/docs.html
    There is plenty of info there to get you going.
    Another place to troll around is in the forums here: http://www.cambam.co.uk/forum/
    Lots of clever people and ideas in there!
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. Moving Table, or Moving Gantry? (For Router)
    By Cryptonic26 in forum DIY CNC Router Table Machines
    Last Post: 04-20-2011, 08:38 AM
  3. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 10:59 PM
  4. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
  5. Moving a part: which method
    By originator in forum Linear and Rotary Motion
    Last Post: 11-03-2006, 06:19 AM
