586,100 active members*
2,684 visitors online*
Results 1 to 11 of 11
    Apr 2007
    327
    Thin aluminum bending
    I have a project that I need to bend thin, 0.025, aluminum. Most pieces will just be a 90 degree bend, no problem there. The question I have is on the pieces that have a 45 degree bend - the 45 degrees is on the outside of the "V" shape - am I describing that right?
    The pieces are 1.5" x 3", after the 90 bend they will be 1" x 3" - the one with the 45 is 2" x 3" and will be 1" x 3" after the 45 bend.
    I was hoping to get by with an inexpensive brake but I don't know about the 45 degree bend. Is this something a cheap brake can do?
    I don't have a way to include pics tonight but can tomorrow, if that would help.
    Gary
    Dec 2004
    1865
    If the brake can do 90 degree bends it can certainly do 45 degree bends. It all depends on how close to 45 degrees you need to be.
    The inside and the outside should both be 45 deg after the bend unless I completely don't understand what you are trying to do.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Apr 2007
    327
    Quote Originally Posted by TOTALLYRC View Post
    Mike
    Only true because I didn't explain myself very well...
    Here is a picture of what I need to end up with.
    Aug 2005
    578
    A very easy bend on a brake..even a cheap Harbor frieght shown here http://www.harborfreight.com/cpi/cta...266&pricetype=
    Apr 2007
    327
    Quote Originally Posted by blackbeard52 View Post
    That brake says it can bend up to 120 degrees - won't that leave me with a 60 degree angle?
    Aug 2007
    264
    A cheap and dirty way to make that brake work would be to add a shim to the bottom die (the one that swings towards you as you're bending). You could also place the pcs in the brake and squeeze them the last 15 degrees also.
    Mike
    Aug 2005
    578
    Oh OK sorry for that brain fart..... here is one that will do the job... a little more but will bend to 135degrees http://www.harborfreight.com/cpi/cta...emnumber=45877
    and another that is cheaper but will certainly do 20 ga. and 135 degrees http://www.wttool.com/product-exec/p...ake_WT_Import_
    Dec 2004
    1865
    Quote Originally Posted by LaserImage View Post
    I would call it a 135 degree bend, but I haven't had my coffe yet. It all depends on your point of view. Mine is usually wrong.
    Most of the small brakes will bend this, you would have to just make sure because it is near the limit of how far I have seen them bend.
    Oct 2007
    13
    another way you can do it is to build a die set and use a press, even an arbor press would work with ow thin the material is. we make them out of aluminum all the time
    Sep 2005
    127
    Don't forget that depending on the alloy, you have a minimum bend radius (the radius at the apex of the bend). If you try to bend the material with a smaller raduis, it will crack. If you need a larger radius that the nose of the brake, just wrap a piece of amterial around it to give you the radius you want. Also be sure you bend aluminum across the grain if you have a choice. (the grain runs with the mill markings) If you are making 2 bends 90 degrees from each other (i.e. a box), lay out the flat plate on a diagonal.
    If you use the proper bend allowance and set back for the radius and thickness, you can make a very accurate flat plate layout. Here is a site with info for calculating bend allowance http://www.engineersedge.com/bend_allow_calc.htm
    David
    Apr 2007
    327
    Thanks to everyone for the help. I bought the HF brake and made some prototypes - they turned out perfect!
    Gary
  1. RFQ Aluminum bending into c channel
    By seansear in forum Employment Opportunity
    Last Post: 07-28-2008, 09:56 PM
  2. Router for thin aluminum
    By Iguanadon in forum DIY CNC Router Table Machines
    Last Post: 05-17-2007, 03:03 AM
  3. Cutting thin aluminum
    By neonguy in forum Waterjet General Topics
    Last Post: 10-13-2006, 02:29 PM
  4. Bending Aluminum Bar
    By energyforce in forum Bending, Forging, Extrusion...
    Last Post: 04-12-2006, 05:09 AM
  5. Bending small aluminum rod
    By Twmaster in forum Bending, Forging, Extrusion...
    Last Post: 08-07-2004, 01:50 AM
