586,036 active members*
3,571 visitors online*
    Feb 2004
    427
    Where to find offset or eccentric bushings?
    I'm after some offset bushings so that I can use them to adjust bearings left and right. Same as what the V bearing wheels use to adjust the play out of them.
    I have search a few online places but can't seem to find any.
    The size I'm after is.
    OD 1/2" (to fit inside 1/2" bearing ID)
    Length about 1 1/14"
    Then have a Hex head so that you can put a spanner on and adjust.
    Other than bugging someone to make me up a handfull of these out of hex shaped bar, there must be something like this already for sale.
    Any ideas?
    Peter
    My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
    Mar 2006
    2712
    Peter, Would eccentric cam rollers fit into your project? Just a thought.
    Dick Z
    DZASTR
    Jan 2008
    4
    My Wadkin table saw uses them for alignment and height adjustment of the table and sliding table. It used to be a reasonably common alignment method in a lot of equipment. Simple to make if you have access to a lathe with a 4 jaw, but I don't think you'll find anything off the shelf and if you did odds are it would be metric.
    BernardR
  1. Eccentric bolts
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 07-27-2014, 02:18 AM
  2. Radius Offset and Length Offset
    By jim_stoll in forum Dolphin CAD/CAM
    Last Post: 10-15-2010, 01:47 AM
  3. where to buy linear bushings?
    By slat26 in forum Linear and Rotary Motion
    Last Post: 03-04-2008, 07:34 PM
  4. X2 drawbar rotating eccentric ...
    By binky72 in forum Benchtop Machines
    Last Post: 02-08-2008, 06:02 PM
  5. RFQ 4 turned bushings
    By SPEEDRE in forum Employment Opportunity
    Last Post: 01-16-2008, 10:53 PM
