586,035 active members*
3,910 visitors online*
    Mar 2006
    107
    Input/output signal on 0M-C
    Is there any way to connect some external switch (as input) or some LED/relay (as output) to Fanuc 0M-C? Some free interface I/O ports that could be controlled through NC?
    This should be used for e.g. touch probe signal (as input), some external accessory (through some relay)....
    That probably depends on installed board or something?
    Sorry for bad english
    24221
    Spare inputs and outputs can be used but requires programming of the PMC using Fanuc software etc.
    The skip input should already be present for touch probe, this is a dedicated input when used with G31.
    Al.
    Albert E.
    Mar 2006
    107
    I just found something in parameters book "tool skip signal TLSKP (G140, #0)". That's it?
    Where can I found phycisal possition of that input/connector, in Fanuc manual or machine manual (Kia)?
    EDIT: Probably I have to found some X adress that is "connected" to G140 in Ladder, am I right?
    24221
    I show the dedicated skip input as X8.7, normally this does not need any further PMC addition to use it, as long as the MTB has not used it for a general input.
    Al.
    Albert E.
  1. No Output Signal
    By tz1238 in forum Machines running Mach Software
    Last Post: 01-27-2008, 09:57 PM
  2. can I output square waves for step signal?
    By mike944 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-31-2007, 02:27 PM
  3. Input signal fails when powering up drivers.
    By Witsenburg in forum CNC Machine Related Electronics
    Last Post: 07-02-2007, 09:02 PM
  4. Diag: Output Signal: Enable 1 help...
    By Flatline's Up! in forum Syil Products
    Last Post: 04-06-2007, 08:11 AM
  5. Physical Button Signal Input Triggering Macro
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 08-25-2006, 04:26 AM
