586,104 active members*
3,373 visitors online*
    Jan 2007
    10
    travaling column mill
    Hi
    I need some help deciding If I should buy a Mazak VTC 41 or if I should buy a regular vertical mill ,can anyone who has run a vertical travaling column mill tell me if there are any drawbacks to this type of mill I would appreciate any advice
    Wayneman
    Apr 2008
    Hallo!
    Two advantages of a traveling column machine:
    - machining on one side, while loading or unloading parts on the
    other side (saves time)
    - easy to set up pneumatic (hydraulic) chucks or tools
  1. Mill Column Mods
    By digitalmdj in forum Shopmaster/Shoptask
    Last Post: 03-30-2008, 02:11 AM
  2. Knee Mill vs Square Column Mill
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2007, 01:27 AM
  3. Round column mill
    By rodzilla in forum Benchtop Machines
    Last Post: 08-16-2007, 02:00 AM
  4. Round column mill
    By SCROMAL in forum MetalWork Discussion
    Last Post: 06-18-2006, 06:23 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
