586,670 active members*
3,327 visitors online*
    Jun 2006
    56
    how do i load xml file
    how do I load an XML file. IM trying to get My G540 working and I found q post and have the file but it is not readily apparent on how to load it.
    Put it in the Mach3 folder, then, change the properties of your shortcut (or make a new one) so the target is C:\Mach3\Mach3.exe /p xmlfile
    (where "xmlfile" is the filename of the xml, without the extension. )
    Jun 2006
    56
    thanks
    thanks, fault light went out and steppers spin with arrow keys.
  1. Replies: 4
    Last Post: 07-12-2012, 08:34 AM
  2. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  3. Spindle Load
    By ISHY in forum MetalWork Discussion
    Last Post: 09-25-2008, 02:59 PM
  4. PMC load problem
    By duccnc in forum Fanuc
    Last Post: 05-21-2008, 05:45 AM
  5. Z load on vf-3
    By mls in forum Haas Mills
    Last Post: 05-16-2008, 04:54 AM
