586,061 active members*
4,589 visitors online*
Results 1 to 12 of 12
    Oct 2008
    103
    victor vcenter-4
    Hello, I just purchased a vcenter4 and I am having trouble setting up the dnc I can not get my computer to send anything to my controller and I do not know how to send anything from the controller.It has a fanuc 10m controller with the tape function. If any body could please give me step by step instructions it would really help I am new to cnc . Thank You
    Oct 2008
    26
    Are you trying to load the program into the memory of the control? What communication software are you using?
    Oct 2008
    103
    Hello, The software that I have is dnc4u. And yes I am trying to load it into the memory of the controller, or send the program from the controller to the desk top.
    Oct 2008
    26
    Generally speaking, you'll put the machine in a DNC or TAPE mode, hit cycle start, then send the program from the PC. Assuming the communication parameters are set correctly and your cable is set up correctly, it should work.
    Oct 2008
    26
    Well, You should be able to push the following softkeys
    to read into the control, select READ > EXEC or you can try READ, Type the 4 digit program number, O1234, then EXEC. This will ready the machine to accept what you are sending it. Your next step is to select the file on the PC and send it.
    To punch a program, bring up the program like you are going to run it, or edit it, on the softkeys, press PUNCH > THIS. Again, the PC needs to be ready to receive the program from the machine before you send it.
    This is all done in EDIT mode and the EDIT key enabled
    Oct 2008
    103
    Thank you for you help, I did get the controller to send a program to the desk top but when I send it from the desk top to the controller I get a sr 833 frame error. Any advice?
    Oct 2008
    26
    Double check your communication parameters on the machine.. Do you have the manual?
    Try slowing the baud rate
    Oct 2008
    103
    Yes I do have the manual for the controller. I have checked the parameters and still get the same error.
    2932
    Please tell us what your comm settings are, both at the control and the PC.
    Oct 2008
    26
    Quote Originally Posted by skippyfix View Post
    Can you post the first few lines of your program? and the last couple lines?
    Oct 2008
    103
    G92 X0 Y0 Z0;
    G91 G01 Y50. OF100;
    X80. Y20.;
    X20. Y-70.;
    x-100.;
    M30;
    Oct 2008
    26
    Is that just the end of the program?
    that is what came out of the machine, right?
  1. VICTOR VMC
    By rajesh_1355 in forum Fanuc
    Last Post: 11-03-2008, 01:05 PM
  2. How are the quality of VICTOR lathes versus Grizzly, etc.?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2008, 01:58 PM
  3. Precision Matthews, GMC, or Victor
    By mtechserv in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2008, 07:11 PM
  4. Replies: 0
    Last Post: 04-16-2007, 06:31 PM
  5. Sony Millstation/Victor mill
    By Theroc in forum Uncategorised MetalWorking Machines
    Last Post: 09-01-2005, 09:16 PM
