586,113 active members*
3,203 visitors online*
    Oct 2008
    Foam Cutting Rotating Axis
    I am new to this forum and i am writing from Italy, so sorry for my poor english.
    I'd like to know if there is a software to generate gcode and cut shapes like this with 2 axis + 1 rotating axis:
    http://www.ronchinimassimo.com/rm_policut_3d.htm
    Thank you very much in advance and
    Warm Regards,
    Federico
    Feb 2006
    17
    info
    ciao federico
    ho letto i post anche sui forum italiani.mi sono imbattuto nello stesso problema ma non ho trovato nulla in rete di commercialmente valido.nessuno gestisce 4 assi indipendenti e il piatto rotante.quella sul sito di ronchini è la macchina Megaplot che costruiscono in Polonia www.foamcutter.pl
    io ho fatto una 4 assi indipendenti ed ho usato il software Cenece ma ce ne sono anche un paio free che girano su linux.poi esiste anche una procedura per mach3 ma è un pò laboriosa
    ciao
    hi federico,
    i find your post on the ather italian forum.i've the sameproblem ma i don't find anything on the web.no one works with 4 axis + the turn table.the machine on the ronchini site is the Megaplot build on Poland
    i build a 4 indipendent axis and used Cenece software but there is a coplu of free program on internet.there is a process for mach but is too difficult e complicated
    bye
  1. 2 axis foam cutting.
    By venomx999 in forum CNC Wire Foam Cutter Machines
    Last Post: 12-01-2012, 08:23 AM
  2. Rotating axis addition - Questions about lathe chucks.
    By tahustvedt in forum DIY CNC Router Table Machines
    Last Post: 03-06-2008, 07:25 PM
  3. Need help with 4 axis foam cutting.
    By bakersman in forum CNC Wire Foam Cutter Machines
    Last Post: 02-17-2007, 02:43 PM
  4. 4 Axis EDM software , used to create foam cutting path?
    By bgriggs in forum CNC Wire Foam Cutter Machines
    Last Post: 09-29-2005, 10:52 AM
  5. Rotating Nut Ball Screw for dual X axis
    By AeroKam in forum DIY CNC Router Table Machines
    Last Post: 08-10-2005, 05:05 AM
