586,108 active members*
3,100 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC2416 tool change problem
    Sep 2008
    I am having problem with a swing arm tool changer.
    When the arm rotates 60 degrees the tool is released about 3 degrees to early. Is there a adjustment to delay the tool release. Mechanical or in the programming?
    Farrell
    Oct 2008
    42
    Possible Problem: It is common for the tension spring in the arm to break (claw), check it and replace it if necessary.
    Jun 2008
    1104
    It could be a speed related issue. Check the oil in the toolchanger transmission housing is 32 or 37 grade. If the oil is too thick, it will slow the tool arm too much at the 0, 60 and 180 degree positions. If necessary, drain and change it.
    Dec 2008
    445
    The swing arm on the BMC2416 is held in place with a tapered lock bushing. It's possible for the arm to become misaligned on the shaft. First use the manual functions to move the arm to the tool change position. Where the arm is grabbing the two tools but they are still in the spindle and pocket. Ensure there is a tool in the spindle and one in the pocket. Use endmill holders with nothing in them if you like, lessens damage due to a thrown tool. Loosen the 4 cap screws at the bottom of the arm. You may need to hit the arm with a dead blow to break the fit on the tapered bushing. If it's simply misaligned, rotate the arm until it's snug against the two tools flanges. Tighten the 4 lock bolts and you are done.
    If you just think it's releasing too early, and it's throwing tools on you, go through the manual functions and when you bring down the arm, you'll probably see a delay in the two pins near the central shaft springing up. They can get gunked up with old coolant and stuff. You might have to take the arm off to clean things out, I had to on the one at work. Cleaned and lubed the whole thing, and every week I make sure the pins are operating smoothly.
    Hope that helps you!
  1. Hurco BMC30 tool change problem.
    By scottjkolb in forum HURCO
    Last Post: 11-25-2011, 09:34 PM
  2. Tool Change problem
    By mattpatt in forum Fanuc
    Last Post: 03-10-2009, 02:05 PM
  3. Need Help With Tool Change Problem
    By AZDEN in forum Fanuc
    Last Post: 11-21-2007, 08:44 PM
  4. VF3 tool change problem
    By cata1351 in forum Haas Mills
    Last Post: 10-19-2007, 12:11 AM
  5. Problem in Tool change
    By ahmedsamy_81 in forum G-Code Programing
    Last Post: 02-14-2007, 04:02 AM
