586,036 active members*
3,917 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > G112 NEED HELP TURNING ON PARAM MIYANO OT
    Oct 2008
    Angry G112 NEED HELP TURNING ON PARAM MIYANO OT
    I HAVE A MIYANO BND34S2 WITH FULL C AXIS ON MAIN AN SUB SPIND. BOUGHT IT USED AN I GUESS THEY ONLY MADE 5 OF THESE WITH C AXIS. IT HAS AN OT CONTROL AND FANUC SAYS G112 IS AN OPTION FOR THAT CONTROL, HOWEVER NEED TO GO THROUGH MIYANO TO GET IT TUNED ON. MIYANO SAYS G112 CAN'T BE DONE. I KNOW IT NEEDS TO GET TURNED ON IN TH E 917 PARAM. CAN ANY ONE HELP?
    Jun 2008
    1511
    I don't know much about the OT control but from what i have seen you should just be able to change the bit you want. Do you know which bit you need from the 917. What is the G112 description.
    Stevo
    Request for Help!
    Quote Originally Posted by INXS View Post
    Dear Sir, I trust you are well. I recently import same Miyano BND34S2 with C axis and subspindle Fanuc OT from UK. There is no Macro programs in the machine and no manual received with the machine. Can you please help me in this regard? I need to have machine M code list plus Macro programs for C axis and live tools. Thanks in advance. Stay blessed.
  1. G112 NEED HELP TURNING ON PARAM
    By INXS in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-28-2008, 08:48 PM
  2. Function to change DGN/PARAM from macro?
    By padobranac in forum Fanuc
    Last Post: 10-12-2008, 10:06 AM
  3. Fanuc param 923 problem ??
    By trotsky in forum Fanuc
    Last Post: 06-22-2007, 03:36 PM
  4. Fanuc motor # for param 8420 OMC
    By OC_ in forum Fanuc
    Last Post: 02-20-2007, 11:55 PM
  5. G112
    By CatCAD in forum G-Code Programing
    Last Post: 12-04-2006, 11:12 PM
