586,052 active members*
4,196 visitors online*
Results 1 to 7 of 7
    Apr 2004
    175
    1/4 to 1/8 collet adapter?
    Can anyone tell me where I can get a 1/4' to 1/8" collet adapter for my router? I have a Dewalt 2 1/4 hp model DW618. The quick change adapter by Porter-Cable sounds good but I'm not sure if it will fit the Dewalt.
    I would like to find a precision collet of some kind. I have read that the die grinder adapters have way to much TIR and will break a small bit. I haven't had much luck in seaching the web in locating a good quality piece. There is reference to one on the " PreciseCut" web site but the link is no good.
    Thanks'
    Chuck
    Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
    Apr 2004
    175
    I'm looking for something along these lines:
    er11 collet
    or this:
    The pic is the one I want but I can't locate a seller.
    The one on ebay will work but it would have to be cut down
    Apr 2010
    Quote Originally Posted by CRFultz View Post
    Thanks'
    Chuck
    This is probably what you need. It's likely where the machine came from and so they just didn't tell you you need this to use 1/8 inch bits.
    http://www.cadcamcadcam.com/sleeve-adaptor14to18.aspx
    or the dual split, which looks more feasible.
    http://www.cadcamcadcam.com/sleeve-a...to316-1-1.aspx
    Mar 2009
    106
    Mar 2006
    80
    Might want to try 'http://www.gpcollets.com/index.html' They gave me good service... !
    Oct 2009
    147
    as long as this is dug up from the dead, maritool sells a straight shank tool holder
    http://www.maritool.com/Straight-Shank-Tool-Holders
    no experience but i'm guessing someone here has used it.
  1. Calculating draw bar force on R8 collet
    By h3ndrix in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2005, 10:51 PM
  2. precision collets
    By twombo in forum DIY CNC Router Table Machines
    Last Post: 05-29-2005, 04:52 AM
  3. Your opinion on adapting my router collet
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 12-03-2004, 06:02 PM
  4. 1/4 Carbide Aluminum Feeds?
    By Cold Fusion in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2004, 02:59 PM
  5. Sealing a collet?
    By HuFlungDung in forum Uncategorised MetalWorking Machines
    Last Post: 04-13-2003, 11:36 PM
