586,106 active members*
3,077 visitors online*
Results 1 to 3 of 3
    Dec 2007
    31
    Need help ASAP
    I have a 1998 Daewoo Puma with a Fanuc 18-T control. I am getting an alarm message that reads (500 OVER TRAVEL : +x) My absolute x reads 39.3811 at the bottom of travel which shoud be a negative number. I can only travel about 5 inches in positive which does not even get me to 0. I cannot use refrence return either. Can anyone help.
    Thanks John
    Ive seen that before. Check your overtravel limit switch. It could be dirty or faulty. Does it improve as the machine warms up? Sometimes as the slides warm up and the machine homes out repeatedly it goes away. Take your finger and depress that little switch with the roller on it and press it like 20 times and see if that helps.
    Im just saying that it could be the limit switch, not that it 100% is. Ive seen it happen before.
    2932
    Turn off the control. Hold the P and CAN keys while the control boots up fully. This will ignore the limits so you can Reference Return it.
  1. ASAP help or advice
    By DrDudley in forum Want To Buy...Need help!
    Last Post: 07-22-2008, 07:40 AM
  2. ASAP Help or Advice.
    By DrDudley in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2008, 11:38 PM
  3. New stepmaster board NEED HELP ASAP
    By sintratech in forum Stepper Motors / Drives
    Last Post: 06-12-2007, 12:54 AM
  4. threading help!!! asap
    By joe1970 in forum G-Code Programing
    Last Post: 04-16-2005, 01:46 PM
  5. need help asap with g12 code
    By jeremyinnys in forum G-Code Programing
    Last Post: 01-22-2005, 03:58 PM
