586,060 active members*
3,892 visitors online*
    Nov 2004
    6
    Contour Shuttle in DeskCNC?
    I'm using a USB number pad right now, and it works fine, but I'd really like to try a Contour Shuttle jog wheel.
    Does anyone have experience getting it to work in DeskCNC?
    Thanks!
    Kyle
    Aug 2011
    Answer long time in comming - pendant
    I have a shuttlepro working with DeskCNC. It works great as a pendant. I also wired an external estop and pause. I also have a large POT wheel to control the spindel speed on the pendant. If you want the data file let me know. I have a few buttons that you may want / need to change. For example I have a button for tool change that executes a home script that takes the machine to a portion of the table for changing tools, another for vacuuming the table, another for moving the head off the table, etc.
    They are easy to change once you see how they are implemented.
  1. Shuttle Pro Problem
    By shane.vella in forum Mach Wizards, Macros, & Addons
    Last Post: 07-16-2012, 01:17 AM
  2. Shuttle In Problem
    By CountBraden in forum Haas Mills
    Last Post: 08-24-2008, 05:57 AM
  3. Could someone help me setup my shuttle express in EMC?
    By fusion_crank in forum LinuxCNC (formerly EMC2)
    Last Post: 06-17-2008, 06:19 PM
  4. VF3 SHUTTLE IN FAULT
    By JACKOFTRADES in forum Haas Mills
    Last Post: 11-29-2007, 05:23 PM
  5. Jog Pendant or Shuttle Controller?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 09-04-2007, 03:47 PM
