586,378 active members*
2,609 visitors online*
    18
    Setting origin on laser cutters
    Is there an easy way to set the origin on a rabbit laser cutter? I want cut images on a piece of paper so registration is important. If I’ve moved the head for a new project and then want to return to an old project I would like the laser to start from exactly the same position as I’ve made a jig to hold the pieces of paper in an exact position. There must be a standard to way to deal with this issue.
    I’ve played around a bit with the Datum but I guess I don’t understand it. It seems as though when I press the datum button it doesn’t always return to exactly the same position.
    Brian
    Aug 2007
    61
    Me too
    I was in the same boat as you till I gave up and do a practice run, then set my final piece. I believe the "Datum" bottom sends the laser head to the top right hand corner. Hopefully someone can add to this problem.
  1. Inexpensive Laser Cutters/Engravers
    By hubery in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-14-2009, 03:52 PM
  2. Replies: 0
    Last Post: 10-17-2008, 04:17 PM
  3. about chinese laser cutters
    By buddhafragt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-04-2008, 11:00 AM
  4. Fabric laser cutters
    By mdiaconu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-18-2006, 09:03 AM
  5. Announcing a new UK supplier of Laser Engravers/Cutters
    By Strelitzia in forum News Announcements
    Last Post: 11-07-2006, 08:25 PM
