586,119 active members*
3,644 visitors online*
Results 1 to 10 of 10
    Jul 2005
    340
    angled bore ?
    Hello all, I see many of wise people around , congratulations !
    I have a simple question : how to make angled bore like in screenshot ?
    The center of the bore is in center of the pocket.
    Peter
    4th axis or angle plate
    interpolate a flat then drill and bore or interpolate the hole
    if your using a boring head and there is a tight tolerance on the bore and positioning , interpolate the start of the bore and leave only a few tenths for cleanup , if you dont you will probably have a messed up bore , it will end up out of round or worse , boring heads dont like interupted cuts
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Jan 2004
    3154
    You can either make a construction sketch that has an angled line to extrude your cut along OR you can make a reference plane that is set at the correct angle.
    www.integratedmechanical.ca
    Feb 2007
    664
    i would put the bore in first so you wont have an interrupted cut at the top of the bore
    fixture at the angle required then mill a flat normal to the bore at least as large as the bore
    then drill or interpolate the bore leaving a wall tolerance then finish with a reamer or boring head
    then reposition the part to put the counter bore in
    Feb 2007
    664
    didn't notice this was a Solidworks question
    me neither
    Jul 2005
    340
    Thank you guys ! the idea with the extruding angled line is tricky , I tried to do it with angled plane , but I have problems with aligning the center point.
    Apr 2005
    713
    Look at the attachment. I run 2005 so if you've got that year or newer, you should be able to open it.
    Edit: Added another way to do it which may be easier for you to get the hole centered in the counterbore. It's a revolved cut.
    Attached Files Attached Files
    Jul 2005
    340
    oh , this is so easy when someone give a rigth direction , thanks all ! now I know !
    __
    Peter
    Jan 2004
    3154
    Stupid of me to forget the revolve. especially considering that is my usual way of this type of feature.
    I guess I will claim too much beer consumed after hockey as my excuse.
  1. How to make an angled radius cut....
    By xtremein in forum Dolphin CAD/CAM
    Last Post: 06-27-2008, 02:01 AM
  2. Engraving around on angled surface?
    By Blink in forum Mastercam
    Last Post: 03-10-2008, 03:25 AM
  3. horn pin (angled pin)
    By spider in forum Moldmaking
    Last Post: 09-29-2007, 01:37 PM
  4. Angled Holes
    By john_mccarron in forum GibbsCAM
    Last Post: 05-31-2007, 11:04 AM
  5. Angled Brackets
    By JohnG in forum DIY CNC Router Table Machines
    Last Post: 05-19-2006, 10:10 PM
