586,096 active members*
3,632 visitors online*
    Jan 2004
    7
    cnc controller blown pcb trace
    Everything was running fine. Left for a few minutes and when I came back nothing was moving. I noticed one of the wires coming in from the power supply was loose so I fixed it but still didn't work. I took it apart and the pcb trace right near the power supply input connector was blown. I fixed it with some conductive epoxy, hooked it back up with the power supply unplugged and it did the same thing, complete with sparks & fireworks . Anyone have any ideas on what might be causing this? Thanks.
    24221
    Is this a PC? Drive? What controller? what power supply?
    Al.
    Albert E.
    Jan 2004
    7
    It's a 3 axis cnc controller (not sure of the brand). It has a separate power supply that powers the gecko drivers and plugs into the control box. I'm getting a reading of about 32V from the power supply, doesn't matter if it's plugged in or not or turned on or off. thanks.
    Jan 2004
    7
    Here's a pic after I repaired it with the conductive epoxy and hooked it back up.
  1. What program do I need to trace?
    By Blacksunshine in forum DIY CNC Router Table Machines
    Last Post: 07-22-2008, 11:15 PM
  2. How To Trace A Bitmap Or Image!!!!
    By jmedick in forum Rhino 3D
    Last Post: 03-12-2008, 04:32 AM
  3. Bitmap trace
    By tdnp in forum Vectric
    Last Post: 02-20-2008, 11:11 PM
  4. How To Trace A Bitmap Or Image!!!!
    Last Post: 11-03-2007, 01:25 AM
  5. Easily trace an image into your CAD
    By Graphcon in forum News Announcements
    Last Post: 11-14-2003, 01:30 PM
