I'm machining the T-Nut blank that came with my Phase II BXA QCTP. I have to take off a lot of material and I was curious how much I can possibly rough cut per pass. Here is my setup....
G0619 Super X3 with Spindle @ 500 RPM, with automatic feed
New 3/4" TIN Coated 2 Flute End Mill
Machining Steel, Manually brushing cutting oil on cutter and work peice.
Must take 0.560" off each eadge to trim width
Must take 0.260" for Thickness
I've done 0.050", 0.075, and 0.100" per pass.
0.100" per pass is not bogging the machine at all but sorta afraid to take much more than that.
I know there is probably no exact answer but I was curious how much metal this thing could possible hog.
