586,399 active members*
3,069 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Need X-Axis cable breakout diagram VF-0 Brush Motor
    Jan 2008
    282
    Unhappy Need X-Axis cable breakout diagram VF-0 Brush Motor
    Yesterday I set out to resolve the Alarm Code 161 that started appearing on my VF-0 1992 VFC. When I pulled the X-Axis motor I found plenty of things that could lead to a ground fault. Brush dust was thick so I cleaned that out. but the biggest problem is that someone at one point had stuffed way too much cable into the connector box pinching the cable in a couple of places and allowing no litle amount of coolent to gather there. Everything was moist and gummy from coolant evaporating from that location. I carefully cut the cable and shortened it but must have made some mistake as this morning I got a Alarm 139 X Motor Z Fault error. Does anyone have any idea of where I need to check for this problem? I would like to find a color coded breakout diagram of the motor connection end of the X axis cables.
    Thank you
    eagle
    24223
    If the fault declares a Z fault error, I would think you do not have continuity on your encoder marker pulse wiring.
    If you do not have the wiring schematic, look at copying one of the other axis, which may be a good idea anyway, if this one was full of carbon, then there is a possibility the others need attention.
    Remember, new brushes $25.00, new Motor because of poor maintenance, $1000.00+.
    Al.
    Albert E.
    Jul 2005
    12177
    That is one of the encoder wires that must be open circuit or wrongly connected. The Z channel on the encoder is the one that gives the ballscrew position signal for zeroing the axis. I don't have any diagrams or anything but perhaps you can take a cover off where the wires enter the encoder and then trace the colors?
    May 2007
    29
    Thanks guys,
    It was a broken wire.
    Eagle
  1. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  2. replacement motor for PML&Kollmorgen DC Brush Servo Motor
    By fymroger in forum News Announcements
    Last Post: 10-24-2008, 09:36 AM
  3. Need controller for small DC brush motor
    By tirebiter in forum CNC Machine Related Electronics
    Last Post: 04-10-2008, 10:53 AM
  4. Brush Servo Motor Sources?
    By bsc52001 in forum DIY CNC Router Table Machines
    Last Post: 05-19-2004, 03:40 PM
