I worked with Mazak multitask before and I like it, but I don't have experience with other brand so I can't compare.
What's do and don't like, advantage and disvantage between these machine?
The best way to learn is trial error.
The Mori NT rocks. Hands down.
The Mori offers special technology such as DCG, box-in-box construction and a lower turret with a direct drive milling motor (just look on their website about all of that). I've had experience with Mazaks for a number of years and while they are decent machines, they - like any other machine - have their share of issues. The Multus is similar to the mark series integrex - not the E series. It's a slant bed design instead of vertical bed. It really boils down to personal preference. The Mori uses a fanuc 30i series controller with a Mori designed interface laid over top of it. The Mazak uses mitsubishi drives with the mazak matrix controller and i'm not quite sure about the okuma. I think they use Siemens drives with their ThiNC controller.
It also depends on your local service. Some areas have better service than others... unless you have a DMG
I've worked with Mazak as well as Mori's. The Mori is the best ..Mazak service is HORRIBLE...
