586,389 active members*
3,173 visitors online*
Thread: 5 axis head
Results 1 to 14 of 14
    Feb 2008
    20
    5 axis head
    was kind of curious if anyone has found any opensource material on a 5 axis cnc router head design. i saw one site floating around the web that had a 5 axis machine that was home built but there were no plans or real information on it. besides the typical commercial lines, is there anything opensource/relatively cheap that can be found?
    Aug 2008
    24
    Describe the type of work you want to do and I can help with 5 axis? What type of machine will you use?
    Mel White
    Sep 2007
    17
    different types of 5 axis...
    I agree that you need to define what you want to do with 5-axis.
    Most people really want 3+2 (3 axis motion + 2 axis positioning)
    Even in the aerospace industry, this is the norm for all but turbine impellers, etc...
    Just my $.02
    Chris Gosnell
    Gosnell Design
    Feb 2008
    20
    well as and architecture student we do a lot of complex models that are mulitsided so this would the primary application. possibly what you suggest cgosnell might be more suited, but i was mainly looking for some basic info on designs and so forth. primarily it would cut blocks of either of foam or wood, and possibly a lot of abstract shapes.
    Aug 2006
    77
    I don't see how a router can have 5 axis, all the same I do get what your saying about doing some complex shapes. Odds are that most of the things you will do are 3 axis in nature using 3D machining to put all 3 axis in motion. For a router to have 2 more axis, you would need a table that pivots axially and diametrically. If you need really complex shapes, I suggest you look into a rapid forming techniques such as Stereolithography (SLA) or Selective Laser Sintering (SLS). Considering the type of work you do, that's were I would put my money at before investing in a 5 axis machine.
    35538
    Quote Originally Posted by Paulo E. View Post
    The tool rotates in two axis.
    Jul 2005
    14
    look at radial arm saws
    I have an old radial arm saw that basically has the 2 extra axis -turns around 360 & drops through 180. It could be used as the spindle motor. but its not small and would need a large strong gantry and z axis to carry it.
    I think its an interesting challenge.
    http://opusinwood.com
    beautiful designs Beautiful woods
    Mar 2008
    7
    Baseball, I don't have any suggestions WRT opensource, but followed a couple of links from your link, and the pictured router plans are available for $150. Not free, but not to bad a price IMHO.
    FWIW I was impressed with the machine... gives me lots of ideas. Thanks for the link.
    Steel2chips
    Feb 2008
    20
    hmm well after i did a little digging of my own i believe this ( http://www.doughtydrive.com/products.html ) was the site you came up with, and while the plans cost 150 dollars to build their machine you would have to email for a price on the rotary heads, which i think i'll do in a little bit. thanks everyone for the input so far!
    Sep 2008
    148
    If it weren't for people like you and your latest find, the rest of us would still be living in the dark ages
    Sep 2008
    148
    Checkout www.youtube.com as there is a video there of a five axis router their. Anther member has a webste at www.cnc4free.com and he has a 6 axis CNC Router and rights a plugin for GMax that creates the necessary nc. code touse it.
    Jan 2006
    738
    baseball,
    I recall seeing some heads similar to that a long time back on ebay. They were single rotary axis heads that could be stacked together. Perhaps a couple of gearmotor heads with an L bracket ?
    Steve
  1. building 5 axis head
    By elrieger in forum Hobby Discussion
    Last Post: 04-16-2008, 01:49 PM
  2. well my j head is a two axis cnc now
    By fast89 in forum Bridgeport / Hardinge Mills
    Last Post: 09-21-2007, 10:11 AM
  3. 4th axis head mount
    By rovingmind in forum Open Source CNC Machine Designs
    Last Post: 01-21-2007, 05:15 PM
  4. 5-axis head attachment kit
    By benergy in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2006, 02:04 AM
  5. Options for 2 Axis Head (to make 5 axis)
    By drewgarth in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 06:37 AM
