586,626 active members*
2,650 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Need help with noise on limit switch cables. Elco or AC cap?
    Aug 2007
    5
    I am currently working on a machine with a lot of noice on the limit switch cables and the swicthes are trigered once every few seconds. I have used the search function on the forum and came up with the solution that you need to put a capacitor over the input and gnd with 0.1uF capacity.
    The question i have is is this capacitor a DC Elco capacitor or a AC capacitor. In my collegue years we have looked at a schematic of a power supply and there i think the elco was for buffering and the normal cap for filtering but i am not shure anymore.
    Aug 2007
    5
    The condensator i have in mind is the FKS3 will this be ok to use?
    15362
    Hi riva
    Put shielded cables in & ground one end of the shield only normally the input end leave the switch end unconnected & trimmed
    Mactec54
    Aug 2007
    5
    I already planned to put shielded cable on the machene but also want to put some capacitors in thetoolbox so if there is still noise on the lines i can filter it out but for this i need to now if it are DC elco capacitors or AC capacitors.
    May 2006
    1469
    Cap like this. It will have "104" on it.
  1. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-17-2008, 12:56 AM
  2. Are mice cables OK for limit switches?
    By artwood_decor in forum Stepper Motors / Drives
    Last Post: 12-24-2007, 11:53 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
