586,599 active members*
3,622 visitors online*
    Nov 2008
    36
    G54,G55 problems
    have a Funuc control on a doosan lathe I'm trying to machine what is a washer and would like to just make 6 every time I pull the stock out using G54,G55 ext. the problem is I can't get it to work I have the right numbers in the coordinates but it dosn't do the value it stays at the G54 how do I fix this?
    Thanks Jeff
    May 2007
    1003
    Can you show us your program? I personally would like a look at how you are programming the job just to make sure that isn't part of the problem.
    Edit: Is G54 Z0 with the other workoffsets being a multiple of the part+c-o+a little extra for facing?
    Nov 2008
    36
    I figured out what the problem was and it was me. For some reason my z home 0 changed to the tailstock end of the travel instead of the chuck where it was last time some the adjustment was add the difference to the next G55 not minus thanks for the help
    May 2007
    1003
    Hope my post didn't sound condescending. It is just that there are guys new to programming posting here along with those with tons more experience than I have. I hate to assume too much. That is why I asked to see what your program looked like first before attempting to offer a possible solution. Obviously in this case seeing your program wouldn't have helped me help you.
    Glad you solved the problem.
  1. PIC Problems
    By niwatori1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-05-2008, 07:57 PM
  2. problems
    By b_rant in forum Vacuum forming, Thermoforming etc
    Last Post: 02-08-2008, 05:04 PM
  3. KMB-1 problems
    By MTMW in forum HURCO
    Last Post: 07-22-2007, 09:40 AM
  4. Arc problems
    By nda22 in forum Mach Lathe
    Last Post: 07-03-2007, 01:19 PM
