586,108 active members*
3,093 visitors online*
Results 1 to 2 of 2
    Sep 2004
    131
    single block switching
    Hello I have an m39 Ajax control on a Bridgeport Boss mill and want to know if its possible when using single block mode to try a program out and when you then press F5 to let it go fully auto, can you get it back into single block mode. I ask this because sometimes when running through a multiple part program you get to the second part and I want to be able to return to single block mode but it doesn't seem possible, am I missing something in the origonal set up of the control. Thanks Colin
    Feb 2008
    280
    You need to press TOOL CHECK to pause the job; turn on single block mode; then press CYCLE START to resume the job where you left off.
    In normal continuous operation, G codes are processed far out in front of execution. This is done in order to find upcoming direction changes and stops, so that decelerations can be precalculated.
    Once the moves have been processed and put in the pipeline, it is too late to change your mind about where the stopping points are (e.g. to decide you want deceleration to a full stop at the end of every line of G code).
    When you suspend the job with TOOL CHECK, then choose Resume, all the G codes are reprocessed. This gives you a chance to change the rules (e.g. ask for single block mode).
  1. stuck in single block
    By Tandem1 in forum Fanuc
    Last Post: 04-03-2020, 10:50 AM
  2. Replies: 3
    Last Post: 03-23-2009, 02:57 PM
  3. Mazak T32 - Single Block - Blinking Light
    By Artur_Chicago in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2008, 04:09 AM
  4. Single Block problems?
    By mark c in forum Mach Mill
    Last Post: 06-15-2008, 08:11 PM
  5. RS232 program block by block
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2005, 07:52 AM
