I am in the process of designing a cnc beam punch machine and require some help in regards to the software side of things. Can a post for mastercam be generated so I can
Use mastercam mill to pick the holes to be punched and a line where I would like a pneumatic saw to cut through the beam extrusion from a dxf file imported into mastercam?
If this is possible I would like the to run the machine from the nc file created. At the moment we have not decided on any software to run the machine , is there anyone with any suggestions for this application? There will be 4 pnematic punches that need to run
Independently and the saw is also electric/pneumatic.
Any help would be appreciated as this is a big learning curve for me.
Regards
Colin
