586,121 active members*
3,421 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor sounds and clicking
Results 1 to 17 of 17
    Mar 2004
    500
    Hi all,
    I was just wondering if this is a normal functioning thing for stepper motors. When I turned them on, the motors all hummed kind of like a shhhhhhhhhhhhh. When moving the motors made clicking noises or vibrations ever once in a while, not sure if this clicking made a pattern or if it was random noises/vibrations. Also, I don't know if when these sounds came up the motor actually stalled for a microsecond. Are these just normal functioning sounds? Not sure if it is because of the wrong software settings or what.
    Thanks.
    6855
    It maybe missing pulses??
    Mar 2004
    500
    How do I know if it is missing pulses, and how do I change the settings so that it works?
    Thanks.
    Mar 2004
    500
    Could it be because of the fact that I may have 200 steps per rev on the pc and the board in 1/8 mode? 1600 steps per rev? But, it seems to be doing the same thing when I have it set and 1600 steps.
    Thanks.
    Jul 2003
    Mine make noises also using Turbocnc, but they are rythmic. I think it would have to be software related because when I run EZ CNC in Win98 they are as smooth as silk and make no wierd noises. I too am curious.
    Mar 2004
    500
    I will try EZ CNC to see if the problem persists.
    Thanks for the help.
    4826
    Could be a ball bearing noise? Maybe the bearings are "dry" or have gotten a bit of dust inside?
    Mar 2004
    500
    Ya think that if it is this, after a little use they will get better?
    Thanks.
    4826
    No, ball bearings do not "wear in" that way. It might be worth an attempt to inject some light grease into the bearings (if you can fit a grease needle between the inner race and the shield or seal). Or, if you can stand the motor vertically on its shaft, and put a couple of drops of oil on the seal, and lift the seal lip slightly with a needle so the oil can get inside the bearing.
    Remember that it is not recommended that you ever remove the rotor from inside the stator housing of the stepper, as a permanent loss of magnetic strength will occur.
    Mar 2004
    500
    But the noise is when the motors are at a standstill aswell.
    Is this driver or software problem then? I really don't want to open up the motor untill I know that's the only way.
    Thanks.
    4826
    Your Honor,
    I submit into evidence the following statement made by the defendant Sanghera earlier today:
    Quote Originally Posted by Sanghera
    ...When moving the motors made clicking noises or vibrations ever once in a while~snip~
    Now he has amended his statement to say that the same noise is occurring when the motors sit still.
    I submit, Your Honor, that these statements are contradictory and that the case should be dismissed.
    It must be the electronics
    Mar 2004
    500
    I OBJECT!!!!!! hahaha
    Well, the motors make the shhhhhhh noise at standstill and when moving, just when moving it clicks once in a while, and vibrates in both standstill and moving. So, if it is electronics, what could it be? The noise is made even with no parallel port connected and just at standstill. Is it because steppers aren't made to standstill for long periods of time?
    Thanks.
    I liked you last post. hahaha.
    Mar 2004
    500
    Well, I tried them out again, and for some reason all of the sudden they went quiet. Then they went loud again. Also, I could only get about 500 hz out of them. If I went anymore, the motors sounded like they were spinning out inside. It sounded like something was moving faster, but not the shaft. I don't know what going on. Any ideas?
    Thanks.
    Feb 2004
    93
    This case sound that you have noise, check your ground and maybe filtered you ac line.
    Hope this help,
    Alex
    Alex
    www.ebfcnc.com
    Sep 2004
    34
    Alex
    Excellent suggestion. Noise may be causing the motors to jump half way to the next step then fall back. A printer I once worked on did this on purpose to get a buzzer sound.
    Sanghera
    Check the connections of all of the wires between the computer and the drivers. Look for any loose wires and possible bad dirty connections. Even on the motor power wires.
    Are you getting wrong results due to missing steps?
    C-nut
    Mar 2004
    500
    I'm not sure about the missing steps. Well, the motors aren't actually vibrating when stalled. They just make a weird noise. Once or twice the motors started up very quiet. I'm not sure if I'm just causing myself a whole bunch of work because these don't sound right. Are your motors quiet with no fuzzy sound aswell?
    Thanks for the input.
    I really appreciate your help here.
    Mar 2004
    500
    Ok, here's what I've got. I have a switch from my power supply to the Xylotex board. When I disconnected this switch and I touched the two wires, the motors would either
    a) make the shhhhhhhhhhhhh and couldn't handle the 1000hz
    B) go quiet and could handle the 1000hz, but when moving vibrate a lot.
    For B) the two wires usually sparked and then made the quiet noise. a occured more often. For B) I think that I might be just shorting the motors or something.
    Thanks.
    Any info is greatly appreciated.
  1. Help with LPT Stepper Interface
    By nickleplated in forum Stepper Motors / Drives
    Last Post: 06-09-2005, 01:28 AM
  2. Testing Stepper motor
    By HighOctane in forum Stepper Motors / Drives
    Last Post: 06-03-2005, 01:51 AM
