586,106 active members*
3,125 visitors online*
Results 1 to 8 of 8
    Oct 2008
    Question mazatrol thread milling
    I have a 2001 mazak fusion 640M and I need a program example for a 1.250 x 11.5 NPT for thread milling. I know to start with manual program and put the tool info in, but not sure after that. Can anyone help me.
    Nov 2008
    7
    tapered thread milling
    I think there's no solution in Mazatrol for tapered thread milling, also with manual programming. Only ISO programming with simultanuly moving for three axes
    Mar 2004
    761
    Dec 2007
    300
    Attached is a Mazatrol Manual Unit sample for a 1-1/4NPT thread using a 3/4 single point tool. Mazatrol tool data controls the cutter offset. I did not test this program so be careful if you run it.
    Attached Files Attached Files
    Oct 2008
    Smile Everything is OK I got it.
    It is so simple in mazatrol with just 5 G codes.
    Dec 2007
    36
    pipe threads
    the only way i've been able to thread mill pipe threads is with an inserted thread mill that has an insert as long as the thread. I did this making gas pump handles for a guy. thousands of them on a v414 with fusion 640m, and a-axis.
    Mikiemo
    Jan 2009
    47
    Thread Mill
    You can use Mazatrol Manual Program to call the tool, start the spindle and position the tool then jumpout of Mazatrol into a EIA program and write a straight line incremental polar movement, sayat 5 degrees from your start position about the centre with X, Y, and Z movement and repeat this 71 times as a sub routine, then put that sub into another and repeat for the number of revolutions that you need.
    Dec 2006
    95
    Did you get get this solved? The answers that I have read here are all long and more difficult than need be. Simple manual program is all that's needed. We cut tapered threads all day everyday. Best thread mill is tool-flo. 2" NPT 8 sec start to finish.
  1. Mazatrol variable thread lead?
    By extanker59 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2008, 07:24 PM
  2. thread milling
    By fourperf in forum Fadal
    Last Post: 11-21-2007, 04:32 AM
  3. Mazatrol T Plus thread cycle in synch?
    By Castle1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-26-2007, 04:22 AM
