586,110 active members*
3,419 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam library downloads?
    Aug 2008
    7
    Hello all,
    I just had a mastercam rep in our office today to give a demo. One thing among many that was mentioned was a material library and tool library. It appeared that information such as feeds, speeds, max depth of cuts, etc, for different tools and materials could be recorded in these libraries. Are there any libraries like this that are available for download where someone has already worked all of this out, or at least gotten close enough to build on? Just a thought!
    Mar 2005
    461
    The MC install comes with some tool libraries. If you wanted more than that you could probably get somebody to share their library with you. Really you'll probably want to customize your libraries for the type of materials you normally deal with. Often times though many people are reluctant to give away files that they themselves spent many days customizing.
    There are different ways to use the libraries also...
    I have my libraries set up with the desired speed/feed. When I use tooling from the library the speed and feed is automatically set.
    Alternatively, Mastercam can set the speed/feed based upon your current workpiece material. This would be the best option if you work on many different materials.
    Personally I cut mostly annealed tool steel or prehard tool steel so I don't worry about setting up the material calculations.
    You could also benefit from developing a "standard" tool library for each machine which consists of your most common tools that can always be used in the same tool # slot. You would then start a new file, import the standard list, then add special tools from other libraries as required.
    Mar 2006
    1013
    No one has ever really taken the time to setup a Tool Library with HSS, Carbide, Cobalt etc... tools. The process Mastercam uses to caluclate Speeds and Feeds works well, when you give it the right parameters (Dia, Tool Material, SFPM, etc..). I've checked it against other references.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    May 2007
    71
    thanks
    Jul 2008
    139
    It would be great if the tool library would give accurate feeds/speeds at will, but I have found it much faster to use a calculator. I have even used the MetCut book once or twice. The need for long or undercut tools makes that "tool library" that might work for me that much bigger. No time for that here.
  1. SCM Record 1 manual, infos, downloads ?
    By degressor in forum CNC Machining Centers
    Last Post: 06-05-2021, 06:49 AM
  2. Free G-Code Project File Downloads
    By W4MWK in forum Hobby Discussion
    Last Post: 10-21-2013, 10:42 PM
  3. Linspire offering free downloads until 9/6/05
    By mvaughn in forum Community Club House
    Last Post: 09-04-2005, 04:00 AM
  4. Software Downloads
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 04-01-2005, 05:20 PM
